Modding PSONE LCD Mod
Discussion in 'Article Discussion' started by macroman, 6 Jul 2004.
  1. vts
    vts What's a Dremel?
    20 Oct 2005
    just ordered an ATI radeon 7000 PCI from Ebuyer. - £24
    well its cheaper than a 2nd hand one off ebay!! just hope this works!
  2. ag3nt_7
    ag3nt_7 What's a Dremel?
    3 Dec 2005
    Well i finally got this mod TO WORK WELL. Once I realised i needed to run a PAL resolution I could get a full screen picture, and it actually looks pretty good, will have to do some micro fidling to get a sexy sexy picture quality but for now videos look great.
    I was just wondering how people have gone installing 2 video cards in their PC. I have a Geforce 6600gt and I was just wondering if anyone knows that a Matrox Mystique will also work along side it, or will windows just bitch? If its not gonna work ill relent and built the CSync circuit, but for now just wondering how people have gone with 2 cards.
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I've decided to go to S-Video as my graphics card in windows refuses to work with the psone screen unless I use a vga dummy.
    So I've cut up a spare s-video cable and have 4 wires:
    yellow
    blue
    white
    brown
    Which wire connects to what on the wires which previously connected to the vga on the graphics card.
    EDIT: Ignore that, I've got another plan up my sleave, hopefully that will work.
  4. Dekode
    Dekode What's a Dremel?
    28 May 2005
    Hi Guys,
    I've now got my PS1 Screen, although its a different layout and im lost.
    Heres a few pictures, any help would be good im desprate!
  5. Dekode
    28 May 2005
    Also, I went to my local electrionics shop, they didnt have any 7.5v 750mA poweradapters, Although they had 500 + 800mA 7.5 adpaters, would those work fine?
  6. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Thanks for this ive spent half a yeay trying to work this out with out any help.
    (stupid dislexic google)
  7. Thos
    Thos What's a Dremel?
    7 Dec 2005
    Maybe someone out there would like to hear this:
    Card: nvidia gforce fx5200 ultra
    Did not use CSync circuit. Instead, I soldered HSync and VSync to the LCD's CSync pin. IT WORKS (after tinkering, of course)!!!
    Now I will try to see if the comp recognizes it on startup by soldering VGA pins 4 and 11 to ground.
    Here's a question for nvidia users: how can I enable clone mode (more like mirroring)? My usual means of doing so (when I have a VGA monitor and TV hooked up) is through the nview software, but when I have the LCD and TV hooked up, I don't get that option popping up for some reason... probably because resolutions are different now. If anyone knows how I can do this, please help. Thanks.
  8. ZeluR
    ZeluR What's a Dremel?
    25 Oct 2005
    It's look like you have got a Thrustmaster LCD, I've got mine working, see my post.
    http://forums.bit-tech.net/showthread.php?t=103008
    Don't give up - Good Luck.
    Cheers
  9. ag3nt_7
    3 Dec 2005
    I soldered the H and V sync together and it didnt seem to change ANYTHING for me, i still had the same dodgy as, never going to work, picture. What sort of tinkering, or do you just mean in powerstrip?
  10. Dekode
    28 May 2005
    I've got my PS1 LCD Screen working.
    But the screen is rolling, and its very green.
    Also, the lcd only works when you boot up with another second mointor then switch to the ps1lcd.
    Any help would be great :sigh: :wallbash: :duh: :waah:
  11. AJB2K3
    12 Dec 2005
    Epia M10K
    I Have mine working on composite on my EPIA MB (IN LINUX) however i cannont go duel screen with a tft (boo) anyho
    Whats the resolution/hsync/vsync values for the screen?
  12. Dekode
    28 May 2005
    Ok Ive got a better picture now, however, it still won't detect as a secondary mointor unless I hotswap from another mointor?
    Since its a PAL Thrustmaster, maybe I have to do that 5v+ trick? If so how would I go about that?
  13. ZeluR
    25 Oct 2005
    I guess it will never detect your PS1 as a secondary monitor. I recomend you to get a second card, then it will not be any problems for windows to detect it, still you must have PowerStrip running.
    I've tried the +5V, and it didn't helped me at all, couldn't see any different with it or without it.
    This is what I tried
    VGA Pin 9 <--------------------> LCD Pin 10 +5V
    Cheers
  14. AJB2K3
    12 Dec 2005
    12V > 7.5V adapter
    Has anyone got there computer to power the monitor via the 12V > 7.5V car adapter?
  15. MrWillyWonka
    25 Jul 2004
    Yes, it's simple connect the postive to 12v molex and the gnd to gnd molex after cutting off the plug :)
  16. Springs
    Springs Boing boing
    29 Aug 2004
    dont suppose someone can help me.... ive just got mine the other day :D wired it up this evening and i can turn it on via the 5v line... now how do i get a picture on it? i have a radeon 9250 and the monitor is connection to the vga port and an active s-video cable to my tv so i can see whats happening..... and ideas??
  17. brinx38
    brinx38 What's a Dremel?
    15 Dec 2005
    Hello, ordered my LCD today and want to mount it into two 5.25" dirve bays..
    I just need to know if the ribbon cable from the LCD itself to the PCB can be detached at both ends.. I think this 30 pin cable could be used as an extension https://secure.lumenlab.com/shop/group.php?id=6
    If not, how do you guys go about extending the ribon cable?
    THANKS..
  18. AJB2K3
    12 Dec 2005
    whats the power drawn by the screen from the psu?
    (i need to know because om on an itx system)
    Arg my sony screen is blurry but i havent modded the screen yet.
  19. MrWillyWonka
    25 Jul 2004
    You know I can't make head nor tail about the s-video thing, I've tried everything but can't get it to work, I think I might be doing something wrong, after looking through pages and pages of this thread more than once and looking on other sites I can't get anything.
    I have the following connectors:
    Am I missing anything?
    First, what do I connect to what? And where on the PSOne screen do I connect this to?
  20. Springs
    Springs Boing boing
    29 Aug 2004
    any ideas on my situation?
Tags: Add Tags
