Modding PSONE LCD Mod
Discussion in 'Article Discussion' started by macroman, 6 Jul 2004.
  1. Soncetina
    Soncetina What's a Dremel?
    14 Oct 2005
    Well last night i figured "why not try and do the vga hack again" on what i thought was a busted screen, it took me about 3 mins to do it this time as opposed to 3 days last time lol. and to my suprise it showed an image, it was a flickery peice of **** as i havnt done the csync+hsync thing and im running nvidia but it was an image all the same. So i went out to get one of those crazy 3rca to 1 3.5mm 4pin jack cables and the whole thing now looks very very very sexy running from my svideo. The 6800gt software is excellent, it allows you to force it to send to tv and change the resolution and frequency on your "TV" and normal monitor seperatly, i dunno if ATi etc do that but it just seemed cool. Il be posting some pics on my project log soon if u wanna see how beautiful it is...
    lol thanks for your help ruger i was very very close to getting a new one
  2. Capt. Ruger
    Capt. Ruger What's a Dremel?
    17 Feb 2006
    Post some pictures. It wouldn't hurt to see if there is any differences between ATI and Nvidia cards. Glad to see it still works for you, Soncetina. It wasn't looking good for you LCD.
    Laters,
    Capt. Ruger :dremel:
  3. his3j3t
    his3j3t What's a Dremel?
    2 Mar 2006
    hi there, got my psone lcd showing a clear picture via svideo through extended desktop. just wondering how do i clone the screen on to the lcd, rather than using extended desktop mode. the graphics card i'm using is radeon 7500 if that helps
    thanks jt
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Just change the mode in advanced of display properties!
  5. his3j3t
    2 Mar 2006
    thats just showing a list of resolutions when i click on list all modes?!?
  6. his3j3t
    2 Mar 2006
    can anyone help? it looking far better than expected!
  7. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Select Display 2, unckeck extent, select Display 1, Properties, Displays, click clone button. If you're using ATI Control Center, have fun figuring it out.
  8. jvnixon
    jvnixon What's a Dremel?
    29 Mar 2006
    Does anyone have a list of pci cards that work best with this mod? Thanks!
  9. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    IIRC the general consensus is that the matrox mystique is your best bet. It has been discussed in the thread if you're willing to plough through it all :)
  10. Capt. Ruger
    17 Feb 2006
    I have heard good reviews from ATi cards, but I am basis.
  11. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Hi
    Got my old ps one screen here, I remember getting it working using the vga mod, but I cut the power plug off!
    Now I cant remember which wire is which.
    Can anyone point me in the direction of a image that shows me which wire is for powering the display!
    Thanks
  12. johnny_gadget
    johnny_gadget What's a Dremel?
    4 Apr 2006
    Hi folks, this is my first post on this forum but I just wanted to thank everyone who took the time to post their results on this mod as it helped me to do my own.
    I have managed to take the mod one stage further and have added a serial eeprom to the LCD so that it can spoof the EDID process and be automagically recognised by windows without needing to use a dummy monitor. This should also enable it to work on dual-head cards directly - I currently have mine hooked up to a IBM Thinkpad and it boots striaght up to an extended desktop.
    The extra parts required are a 24LC21 EEPROM, a 47kohm resistor and a 10kohm resistor. If anyone is interested, post a reply and that will motivate me to write it all down and draw a proper diagram!
    Cheers all,
    John
    UK
  13. ZeluR
    ZeluR What's a Dremel?
    25 Oct 2005
    :clap:
    Yes - please write a diagram over it.
    Good job!
    :clap:
  14. Nexxo
    23 Oct 2001
    I love you. :clap:
    ...in a totally male geek bonding, platonic sense, of course. :worried:
  15. johnny_gadget
    4 Apr 2006
    Okay folks, I am preparing a web page and will post a link to it soonest.
    John
  16. Springs
    Springs Boing boing
    29 Aug 2004
    lust to let some ppl know... Custom PC have done an article on this..
    issue 32 pgs 94-96
  17. johnny_gadget
    4 Apr 2006
    I have now prepared a really quick web-page with the details, you can find it at:
    www.firingnow.com
    John
  18. user0001
    8 Sep 2004
    Simply :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    Thanks for this invaluable technique. I have yet to try it (need to find the part first), but were there any specific values that you changed in the EDID? Which settings did you enter?
    :thumb:
  19. Nexxo
    23 Oct 2001
    --not involving Johnie Gadget's solution, however. Just a description of the mod as outlined in the Bit-tech article.
  20. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Really good job on this one! Lets see if i am able to pull this one of too!
    thanks again!!!
    P.S. Just one thing. In your post you say that you need the eeprom, 47k ohm and a 10k ohm resistor, but in your guide it says 2x 47k ohm. So i think you have a typo there :D
Tags: Add Tags
