Modding Psone lcd question
Discussion in 'Modding' started by Bboy_Jon, 17 Mar 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    for hooking it up through composite can any cable like the sony one work? or do you NEED to use the sony one?
    and with the cigarette lighter adapter, can you use any or just the sony one?
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    For the composite cable any that have the correct connectors should work since RCA is an industry standard. For the cigaretter adaptor just so long as the power ratings are correct you'll be fine.
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
