Modding PSOne LCD Screen [NEED INFO]
Discussion in 'Modding' started by sergeth, 8 Jun 2004.
  1. sergeth
    sergeth What's a Dremel?
    8 Jun 2004
    Can someone please help me?
    Im trying to setup a psone screen i have onto my computer using the standard cord that came with it (Just: Yellow (Video), Red(Right Audio), White(Left Audio))
    and am having lots of trouble.
    The sound works perfect but NO pitcture shows up at ALL, i even plugged the vidoe cable into the sound plugs, shouldnt the screen show garble or SOMETHING?
    P.S. Its not broken as it works with my PSOne perfectly fine.
    Help Appreciated :clap:
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    You probably just need to enable your graphics cards TV-Out function, and set it to the right mode.
  3. sergeth
    8 Jun 2004
    nope, it doesnt show up from the television set tv-out either, and as i said, the lcd isnt broken cos it works with the psone :(
  4. Nexxo
    23 Oct 2001
    Er. Why would a television have a TV OUT? Aren't you plugging it into the TV IN? :worried:
    Plug it into your DVD player or VCR instead, see what you get.
  5. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    What make is the screen ?
  6. Nexxo
    23 Oct 2001
    Here's some more info on people having trouble with the PSOne screen, and their fixes:
    http://www.diyaudio.com/forums/showthread/t-32292.html
    They suggest you have to connect the metal outer casing of the VGA connector as well, as it's not just shielding but part of the circuit.
    http://forums.hexus.net/showthread.php?t=17938&page=3&pp=15
    Talk about putting some resistors in the cable (75 Ohms) if the card doesn't detect the LCD
    http://www.mp3car.com/vbulletin/showthread.php?t=26080&page=2
    has a TTL circuit to allow it to work with various cards, and Powerstrip
    http://www2.cs.uh.edu/~scamp/
    A small list of cards that do and don't work with the screen.
    Hope this helps.
  7. Redimp
    Redimp What's a Dremel?
    16 Aug 2003
    I think PAL psone screens need a 5v signal on one of the ps connector pins (pin 10?) to turn the screen on.
    more info here.
  8. Goreblast
    Goreblast What's a Dremel?
    6 Apr 2004
    Anyone got info on whether the screen will work with a Radeon 9800XT? If not could you put an old PCI card in (matrox G200) to control just the LCD?
