Modding Psone - using s-video
Discussion in 'Modding' started by Veer, 3 Oct 2005.
  1. Veer
    Veer What's a Dremel?
    3 Dec 2004
    I have a question, i got my psone screen a few weeks back and unfortunately was not able to hook it up to my computer. However then i order an rca to s-video extension, so that i can connect it directly to my graphics card. The problem is, even though everything is connected properly why isn't the psone screen turning on, and there is no picture of any sort? I asked a few questions in the psone thread in the article discussion section to no avail. Please can someone help me out.
    The graphic card i am using is an ati radeon 9600 series. with vga, dvi and s-video input.
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    What power supply are you using for the screen, and is it NTSC or PAL?
  3. Veer
    3 Dec 2004
    the screen is a Pal, and the power supply is Ac adaptor 7.5v. The standard adaptor that came with the screen
  4. ElThomsono
    18 Mar 2005
    Looking at the picture, there are two connectors to the screen. Take the wire on the very left of the right connector, roughly here:
    And connect it to the solder point shown, this should initiate the screen as if the dcc wire was active.
  5. Veer
    3 Dec 2004
    nice. would it be possible to post a larger vesrion of the pic, it's not that clear.
  6. Veer
    3 Dec 2004
    2ndly i am afraid i don't have have a solder gun :sigh:
  7. ElThomsono
    18 Mar 2005
    Big enough for ya? :naughty:
    I just rattled it off 5 mins ago, so it's not connected anymore, but you can still see which wire to connect to which point. Hopefully it's clear enough :)
  8. ElThomsono
    18 Mar 2005
    Get one, they can be had for as little as £5. Isn't there anyone you can borrow one from?
    A voltmeter would also be handy, they can really help with a mod like this one.
  9. Veer
    3 Dec 2004
    nice :), thanks a lot for the pic, i shall give it a shot. I have only gone as far as disassembling the bottom front panel, so I still have to take off the main panel for the screen. Lets see how it works out, and hopefully it should work. :)
    As far as solder gun goes, I shall get one if it is that cheap :)
  10. dastt
    dastt What's a Dremel?
    23 Apr 2004
    did u enable the secondary screen option? if u dont the screen with be blank
  11. Veer
    3 Dec 2004
    yep i tried everything in the display properties. even tried powerstrip and ati catalyst. But catalyst some did did not recognize screen.
  12. Veer
    3 Dec 2004
    but if there is another procedure, then please do tell me.
    and Elthomsono: are you sure it's going to work, by soldering?
  13. Veer
    3 Dec 2004
  14. Snipes0990
    Snipes0990 What's a Dremel?
    4 Oct 2005
    I dont know if this will help you but i used a tv over my s-video connection but i used an nvidea card so i dont know how ati's cards are set up
    let me know if this helps because there might be a different way to go about doing that
  15. ElThomsono
    18 Mar 2005
    So Snipes, you joined this forum just to help someone?
    Cool. Welcome to bit-tech :)
  16. Snipes0990
    4 Oct 2005
    well yes you could say that but i have bean meaning to get a username because i am about to start a modding a game server for me and my friends lans
  17. specofdust
    specofdust Banned
    26 Feb 2005
    The best type of user, welcome to bit-tech :D
  18. Veer
    3 Dec 2004
    snipes: thanks for the screenshots. I've already tried everything with the ati gfx card. Extend desktop etc. The funny thing is it is not detecting the screen, and the screen seems to be off/blank. :sigh: As far as i know, i think the gfx card should detect a monitor via s-video.
  19. Nexxo
    23 Oct 2001
    Welcome to the forums, Snipes0990. :clap:
  20. ElThomsono
    18 Mar 2005
    When I did the vga mod the screen wouldn't turn on / do anything. The wire mod sorted it, the screen instantly reacts as long as the wire's soldered on and the power supply is plugged in, even without any actual video inputs. I think it's time to buy that soldering iron... :)
