psp headphones
Discussion in 'Gaming' started by Springs, 27 Sep 2005.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    any one no where i can get some decent headphones for the psp... i would like to keep the remote part and just get the small headphones..
    any ideas?
  2. mushky
    mushky gimme snails
    24 Mar 2003
    If you want ear-bud style ones then Sennheiser MX550s would be a good choice. They are an open design so you can still hear whats going on around you. If you want total noise isolation then have a look at Shure's offerings.
  3. neillyb
    neillyb What's a Dremel?
    7 Jan 2005
    Personally, I find the ones bundled with the PSP value pack to be more than satisfactory :O
  4. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    Sony Ex71SL 's are a awsome quality earbuds but they are the proper in ear type. One thing you mentioned is that you wanted to keep the remote the Ex71's come with a detachable extension that you can remove if you want to use a remote with them, and they are waay cheaper than any of Shure's offerings. Heres some more info : http://reviews.cnet.com/Sony_MDR_EX71SL_WK_black/4505-6468_7-30520512-2.html
  5. Springs
    Springs Boing boing
    29 Aug 2004
    the ones that come with the psp are the worst ever.... limited to 90db.... can hardly hear any movies that are played, music is ok .. but like i said cant hear the movies..
    i will have a look at whats been offered..
  6. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    you can use any earphones with a standard jack with the remote (it doesn't use the mini jack that was popular with the earlier batch of sony minidisc/CD player remotes.
  7. Springs
    Springs Boing boing
    29 Aug 2004
    i no that... its just i dont want the extra length of cable..
  8. Krazeh
    Krazeh Minimodder
    12 Aug 2003
    You must be half deaf if you can't hear movies using the bundled ear phones, mine are quite loud enough especially if you change the UMD volume to +2 in the movie settings.
  9. eek
    eek CAMRA ***.
    23 Jan 2002
    my headphones suck, listening to my psp using my brothers (jap) headphones and its much louder... not sure if mine are busted or just if jap ones arnt limited, either way i need a new pair! I'm gonna wait and see what the ones which come with the w800i are like, should save a few pennies if i dont need to buy another pair!
  10. [sinz]
    [sinz] What's a Dremel?
    14 Sep 2005
    I use Etymotic ER6i earbuds. They're isolating so you never hear outside noise and the sound quality is pretty good. They're a bit expensive though, I paid $115 USD for them but I needed the isolation feature and I have a very discerning ear.
