Hello! As the title suggests i'm planning on modding my PSP! I have removed the UMD drive because it doesn't work (i only play ps1 classics anyway) and now I want to make use of all that free space and I have come up with a couple of Ideas... I could mod a better speaker into the case, supposedly all this takes is connecting a speaker to the current speaker connectors, the problem is I have no idea where to get a decent small speaker from :s I have a speaker that is the right size ( 35mm diameter 5mm width) but the quality isnt so great Or / and I could mod a PhotoFast CR-3100 int it than hook up 2 sd cards for a massive 32GB storage space So as i know how I would do the memory mod I'm asking what speakers are suitable for the job? would it be possible to have both the new and original psp speakers running at the same time? thanks Hodgy100
Not sure about putting more memory in it, but if you wanted to put new speakers in it, that is possible. I'm not sure how well the psp could drive those speakers though.
its all been done before http://www.youtube.com/watch?v=-rLTBKEkHNw&feature=related Its just that I'm not sure on what kind of speaker to use :s the one I have that could be used is only 0.6W so I could do with something with a little more oomph
