Modding PSP screen mod? can it be done?
Discussion in 'Modding' started by HaVoK, 10 Dec 2008.
  1. HaVoK
    HaVoK Mad Dude ;)
    10 Dec 2008
    Hey guys I'm new to posting on bit-tech.net. I have a question ... Is it possible to mod a PSP screen into a desktop case or even just a second monitor? I've been seeing the old PS1 screen being modded into cases. I have an old bricked PSP and i want some use from it rather than a paperweight.
    I've been looking around for a while but haven't come across anything useful yet so i figured ill ask you guys :D
    Thanks for any info fellas,
    Much appreciated
  2. jhanlon303
    7 Sep 2006
  3. popotheflyingpanda
    popotheflyingpanda What IS a Dremel?
    20 Nov 2008
    Hmm... I remember a mod that used the whole psp connected through usb to display w/e but since yours is bricked....i dont know
    What are the projects you saw the mod on? and did they have a log some where?
    I may want to use this b/c I have a psp i dont use (but its not bricked :D )
  4. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
  5. HaVoK
    HaVoK Mad Dude ;)
    10 Dec 2008
    I pulled the PSP apart last night and got the screen out, this is what I'm wanting to mod into two drive bays.
    these are the pics of the screen ...
    it says Sharp LQ043 K3146 on the bottom of the screen if that's a help guys.
  6. popotheflyingpanda
    20 Nov 2008
    blarg. that's a sticky situation, I don't think you can run a screen w/o at LEAST the psp mother board, i could be wrong, but i poked around a bit and you need the whole psp to run the screen.
    if you want a screen you could try the ps one portable screen or the like, ben heck has used them for many projects, but I'm sure you wanted to use the psp screen b/c you had it ... well good luck
  7. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    You need the LCD controller for the screen, chances are is the controller is part of the PSP motherboard.
    that's the only way to get it working.
  8. HaVoK
    HaVoK Mad Dude ;)
    10 Dec 2008
    yer mate i was thinking of getting that PSP working again somehow and doing it that way just wire it all into the computer PSU.
    BUT still fellas if i can do it just by the screen without the actual PSP components (m/b etc) that would be great ... It's bricked so all i have is the screen :(
    UNLESS if there is a way of soldering straight onto the PSP's motherboard LCD?
    here's the pictures of the motherboard
    If anybody can tell me where 2 get some schematics of the motherboard i might be able to figure something out ...
    Sorry to any one who disagrees about a PSP post on bIt-tech.net but hey it is for a computer case mod :D
    and again ... thanks guys
  9. Prestidigitweeze
    Prestidigitweeze "Oblivion ha-ha" to you, too.
    14 May 2008
    Not to steer you away from this incredibly friendly and useful forum, but you might also ask about your project on a forum dedicated to PSP modding:
    http://www.acidmods.com/forum/index.php?board=361.0
    The denizens of those boards tend to be friendly and helpful, too. If you receive information there which changes your approach or solutions, please be sure to tell us about it here!
    It seems to me that, since the majority of members are modders, they'd have to have pdf'd schematics lying about to check their own work. I can't imagine you'll go hungry in that respect.
  10. HaVoK
    HaVoK Mad Dude ;)
    10 Dec 2008
    cheers mate will do :D
  11. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
  12. HaVoK
    HaVoK Mad Dude ;)
    10 Dec 2008
    Good work mate i wouldn't have let the opportunity slip away either ... good interview
  13. Prestidigitweeze
    14 May 2008
    HaVoK: Whatever happened with your project?
  14. Henri
    Henri What's a Dremel?
    21 Jan 2003
    Answer to the question "can it be done?" is yes.
    You can see some pictures of a USB interface board for a compatible display here:
    http://mylcd.sourceforge.net/libmylcd/usbd480/index.html
    But to make it all yourself might need quite a lot of electronics knowledge. The datasheets for the displays are available and that should be the first place to start from when thinking of connecting the display to something.
  15. identikit
    identikit Minimodder
    5 Jun 2004
  16. Tec_
    26 Feb 2008
    god there is so much custom code work that needs to be done whit those. i hate writing code! but i want that controller so bad
