PSU PSU advice
Discussion in 'Hardware' started by gilljoy, 9 Dec 2010.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Well I've just left down my desktop to the local pc store where I bought my parts to get tested and the guy said he was pretty certain it was the PSU so theres a chance I'll more than likely be buying a new psu so some advice would be brilliant.
    I've currently got a FSP everest 1010w ( probably abit of overkill).
    what PSU would you recomend from PCworld(yea i know pc world are crap but i can get it today), Scan or mplex.com.The other sites usually charge me a surcharge (Northern ireland surcharge sucks)
    running:
    i730 at stock
    gigabyte ga-x58-usb3
    1 sata dvd-rw
    2 1tb HDD
    ati 4850 ( soon to be gtx570).
    Budget is max £139.
  2. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Firstly, what was the original problem? The techy might not be right (all too often, small computer shops...don't have a clue what they are talking about). Not saying that the guy doesn't, but just in case.
    If it is the power supply, you won't really need anything more than a good 450W or so if you're going to be sticking with the single card setup, and around 600W+ if you're looking at anything more than that.
  3. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    the system was randomly powering off out of the blue for no reason.
    I ran memtest everything passed,
    ran intel burn test for an hour at max settings and it was fine,
    check the gpu with ati tools and it was grand
    checked the HDD's.
    only thing left that it could be is the mobo or PSU (process of elimination and all that)
    I'll be upgrading to a gtx 480 or gtx 570 in a few weeks so I need to be able to power that and have room to spare for a 2nd in about 6 months as im upgrading to a higher res screen.
    the shop isnt too small its got 4 stores around northern Ireland so its no the biggest but its not a little tiny indy store.
  4. bagman
    bagman Minimodder
    18 Apr 2009
    get a xfx 650w you can't buy a decent psu from pcworld
  5. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    cheers man, I can get a coolermaster modular PSU from pcworld so I think you can get a decent PSU
  6. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    Well I went to pcworld.co.uk and I couldn't see any Cooler Masters, I tried finding a Northern Ireland website, but no success. So if you want the best recommendation from pcworld then I think a link would come in handy.
  7. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    "the system was randomly powering off out of the blue for no reason."
    Have you asked them to check if there was a short?
    Also, which CM PSU's are PCW selling? What's your budget? I appreciate you want a new PSU asap, but it's an important component so worth some patience to get right.
  8. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Corsair hx750 @ pcworld
    Well the system is down at the store atm still. The guy in the store doesnt seem to know whats causing it, he's reinstalled windows and it seems to have fixed the problem, tho i installed it 4 times over the past week and it kept randomly powering off and giving me the message "The system failed to boot due to overclocking settings or voltage issues" even tho I've not overclocked the system so he's going to keep a hold of it for a few days.
    its not a short as I've double and tripple checked that its not a short.
    budget is around £130
  9. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    They seem to stock some OCZ, Corsair and Antec power supplies, any of which should be good. If you're willing to spend over £100 the HX 750 is excellent, but you don't really need more than 500-600W max.
  10. markbrett64
    12 Jan 2010
  11. sb1991
    31 May 2010
    Yeah, the prices are a bit OTT. If the OP wants to go for SLI at some point then yeah, 750-850W would be a better bet.
  12. trig
    trig god's little mistake
    10 Aug 2006
  13. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    ohh intreasting so will my system plus a GTX570 run on my corsair 550W psu?
  14. sb1991
    31 May 2010
    Should do, yep.
  15. trig
    10 Aug 2006
    assuming you have an average system, 2-4 opticals/hdd, nothing out of the ordinary for cooling...absolutely
