PSU PSU ADVISE FOR THIS BUILD.
Discussion in 'Hardware' started by Kronos, 10 Mar 2010.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Asus P7P55D LE P55 Socket 1156 8 Channel Audio motherboard
    BX80605I5750 - Intel Core i5 750, S 1156, Lynnfield, Quad Core
    Arctic Cooling Freezer 7 Pro Quiet Intel CPU Cooler
    OCZ 4GB (2x2GB) DDR3 1333MHz/PC3-10666 Platinum XTC Triple Channel Memory
    Sapphire ATI Radeon HD 5770 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card x2
    Kingston 64 GB SSD V series harddrive
    1TB Samsung SpinPoint F3 HD
    Hitachi 250GB SATA Hard Drive
    Xigmatek Midgard case
    Dell 2410 A01
    Mionix Saiph 3200 gaming mouse
    Saitek Eclipse 111 keyboard
    Windows 7 ultimate
    I appreciate that some components here have there own power supply,I am just to lazy to filter out the list.
    I have had a look at the reccomended psu list but feel that I do not want to get too big a supply when it might not be needed.
    Always had good advice here so look forward to suggestions.
    Regards.
    Glenn.
  2. adam_bagpuss
    24 Apr 2009
    a good 500W PSU will do that no problem providing you arent going to add anythying extra too it.
    500-650W is all you will ever need.
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Easy get a Corsair 850watt, rememering you may go crossfire at a later stage or bigger
  4. rollo
    rollo Modder
    16 May 2008
    650 watt is still enough for crossfire
    hell you could prob cross fire 2 5770s on a 500watt psu to begin with
    850 watt is what 2 * 295 area
  5. mrbungle
    20 Sep 2004
    bit overkill but it is exactly what I did.
    has a 7 year warranty and tbh you want need another psu for years and years
  6. adam_bagpuss
    24 Apr 2009
    unless they change some connectors then your screwed lol
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am actually using a OCZ Fatality 550w power supply with the twin 5770 grapic cards, but was wondering if I should go a little bigger and upgrade the psu. But it looks like this is not needed.
    Am I right?
  8. adam_bagpuss
    24 Apr 2009
    nah 550W is perfectly fine for your system even with an overclocked 750
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks all.
  10. azrael-
    azrael- I'm special...
    18 May 2008
    How about one of the new Seasonic X series PSUs? Not the cheapest, but quite possibly the best there is (at the moment).
