PSU bang and flash
Discussion in 'Tech Support' started by Twink91, 23 Jun 2020.
  1. Twink91
    Twink91 New Member
    23 Jun 2020
    Hi all
    Yesterday morning the power supply unit seems to have shorted, which tripped other areas of the flat. We did not realise it was that at the time - the computer was off and wasn't being used.
    We turned on the computer a few hours later and the power supply unit gave off a very loud bang and flash of light. Everytime you flipped the switch at the back it did it. Replaced the power with another brand new power supply that we had. It turned on fine for 5 mins last night and thought the issue was fixed. However when we turned the PC on this morning exactly the same happened. A very loud bang and large flash. Any ideas?!
    Thanks
  2. kim
    kim hardware addict
    10 Jan 2016
    Although this would be the first time I hear about it inside a PC, all symptoms sounds like a shortcut....a live wire somewhere ? :worried:
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    This feels like a faulty motherboard to me.
