PSU PSU Blown?
Discussion in 'Hardware' started by seebul, 5 Aug 2010.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi there, my desktops been acting funny recently, the overheating alarm keeps coming on and it restarts itself alot. I opened it up this morning and four of the pins on the power supply connector to the motherboard are brown, as if they've blown or got very hot.
    The corresponding plugs on the motherboard are also abit brown, does this mean new motherboard and psu??
  2. Teelzebub
    27 Nov 2009
    I would try a new PSU first.
  3. J05H11E
    J05H11E Fujitsu Technical Analyst
    5 Aug 2010
    I agree, try the PSU first, if that doesn't work then obv. the mobo
  4. seebul
    seebul Minimodder
    9 Aug 2005
    Cheers for the replies, tried a new PSU but just kept turning itself off. Anyone recommend a good cheap desktop? building is out of the question at the moment just need something cheap to tide me over for a while!
  5. Hypnosam
    Hypnosam What's a Dremel?
    12 Mar 2010
    Whats your price point? And Do you need a whole new PC or just a mobo bundle and PSU?
  6. Teelzebub
    27 Nov 2009
    Are you looking for parts or a whole pre-build ? I may be able to help.
  7. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    What is your Board model ? And what type of PSU it is
  8. seebul
    seebul Minimodder
    9 Aug 2005
    The board is an Abit IS7, i built it 5 years ago and I can't really be bothered to keep fixing it all the time! think im just going to buy a cheap pre-built off ebuyer or something. My price point is max £400 at the moment, but I have a monitor and everything else already.
  9. rollo
    rollo Modder
    16 May 2008
    go dell if you must get a prebuilt or overclockers or scan even
    dont just buy something crap of ebuyer as they are really a poor company to deal with had alot of issues in the past with graphics cards from them and then got put on to a person who spoke very poor english and struggled to give me a return address
  10. Parge
    16 Jul 2010
    To the contrary I've always had great customer service from ebuyer and would recommend them to anyone.
  11. J05H11E
    5 Aug 2010
    same here :)
  12. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Well, you could just buy the following if you need a super basic PC presumably you've got the bits to rip from your current PC to finish it.
    Athlon II x3 440
    Gigabyte GA-MA78LMT (VGA)
    350W Antec Basiq Power PSU
    2GB Corsair Value Select, DDR3
    £168 off of Scan.
    Lot cheaper than £400 and will have you up and running with a not too shabby effort!
    Edit.
    Or you could get an E5400 with the Asus P5KPL-AM iG31 and 2gb DDR 2 for £152.
