PSU PSU Dying?
Discussion in 'Hardware' started by The_Crapman, 19 Feb 2015.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    I've been getting random restarts, both while gaming and on desktop/browsing, no BSOD just a reboot. There's no crash dump files being created as far as i can find and research online seems to suggest my PSU could be on it's way out.
    Thought i'd offer it out to the knowledgeable folk here for any other suggestions on causes. One possibility could be my damaged mobo?
  2. jinq-sea
    15 Oct 2012
    It's probably the missing cap!
    Sent from my iPhone using Tapatalk
    The_Crapman likes this.
  3. Noob?
    Noob? New Member
    18 Oct 2009
    ^^Whats the mans just said!
    You can swap out the PSU by all means to check if it is that, though you can't rule out the motherboard given it has a fault/component missing.
  4. TheMadDutchDude
    23 Aug 2013
    I reckon the motherboard is on its way out more so than your power supply.
  5. The_Crapman
    5 Dec 2011
    Dam. Problem is that it's so intermittent that even swapping out the psu might not show it for a while. Could play a game for a couple of hours no problem, then restart after gaming and just browsing. Or other way round. Will have to keep an eye on the mp that's for sure.
  6. bulldogjeff
    2 Mar 2010
    I have said this on here before about sudden power outs on PSUs. Check the kettle lead.. I drove myself nuts for about a week testing everything and that was all it was, just a dodgy connection.. Rule out the obvious before you strip everything down.
    I actually looked at this as PSU drying, might first thought was how did you get it wet..:D
  7. The_Crapman
    5 Dec 2011
    Will do. Will also get a surge protector see if it's something with the electrics in the flat. Had a new bulb go pop the other day.
    It's not so much wet as, :worried: , 'sticky'.
