Modding PSU extracter!!!!!
Discussion in 'Modding' started by M_D_K, 25 Oct 2002.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I've just got hold of 6 Server Papst fans (120mm version) their pritty cool.
    I got an :idea: to put one of them into an old PSU shell cause the case i got at the mo has the ability to have 2 psu, i was running two then took one out.
    What it will do in the end is sit over my CPU and suck all the hot air away from my it and exhaust it out the back.
    Picys on the way
    ? has any one done this before or is it ne :D
    Suggestions welcome
    What i mean is gutting the PSU and then just putting the 120mm fan in it
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    http://www.bit-tech.net/article/44/
    macroman put a 80mm in but the premis should be the same...the only problem I could see you having is space... he had to do some serious changes to get the 80mm in... but is a cool idea..
