Electronics psu fan replacement
Discussion in 'Modding' started by honyin, 18 Jun 2009.
  1. honyin
    honyin What's a Dremel?
    8 Mar 2009
    hi all i am thinking of changing the fans in my psu with quieter ones the problem is the new ones run at 1500 rpm and the old ones at 2500 rpm can i still change them.
  2. gaz_360
    gaz_360 Make that change
    24 Apr 2009
    you would have to get a fan controller so you can change it, but im not sure that it would work in a PSU, suppose the concept is the same though?
  3. stuartwood89
    20 Aug 2008
    You may get an increase in temperature due to the lower speed of the fan, although depending on the quality of the fan and the design of the blades, it might not matter too much. In terms of voltage, it's all 12V so as long as it's a case fan, should just be a straight swap.
  4. ry@n
    ry@n Minimodder
    31 Aug 2005
    I don't think gaz_360 read your question properly, what PSU is it? and how many fans are in it currently?
    As Stu said, it may increase temps but if you are replacing the fans with ones that move near enough the same CFM it shouldn't be a problem.
    Also, be careful when handling the inside of the PSU, the caps hold charge.
  5. gaz_360
    24 Apr 2009
    ah sorry I didn't read it properly, my bad :wallbash:
    I thought you meant that you had brought a fan that is slower than your old one and wanted to change it to the same speed as the old one.
    Like mentioned in the other posts you will probably see temp increase on various components but should be ok :)
    Sorry again
    Gaz
  6. capnPedro
    11 Apr 2007
    I swapped the stock fan in a 330W Coolermaster unit with a Noctua. It puts out very little airflow (but no noise!) and the PSU's been running fine for near two years now, pretty much 24/7.
  7. stuartwood89
    20 Aug 2008
    Yeah I did the same, but with a Nexus fan. It still works just as well as the stock one did, and heat isn't that much worse off considering.
  8. honyin
    8 Mar 2009
    thank guys the new fans are xilence 80mm red wing case fans
  9. capnPedro
    11 Apr 2007
    Quite a good fan if memory serves; a little louder than Noctuas (my weapon of choice for silence) but the airflow is better.
    Out of interest, what PSU has an 80mm fan? :worried:
  10. stuartwood89
    20 Aug 2008
    Quite a few cheaper or older PSUs. Of course most new units have 120mm or higher fans, some even have both.
