Electronics Psu fan
Discussion in 'Modding' started by Dholmblad, 3 Sep 2004.
  1. Dholmblad
    Dholmblad What's a Dremel?
    29 Aug 2004
    Well i have a crappy 350 watt psu that came with my raidmax, and i dont use it so i saw it had an 80mm fan in it which was sodered to the board. So i took it off and 1st i decided to splice the wires to a molex connecter with some wires alrdy on it. Then i tested it it didnt work... So i tryed just sodering the wires that came from the molex connecter to the fan. Still not working... Is it a conflict of dc??? I do not know much about electonics
  2. Go4t
    Go4t i
    13 Dec 2003
    the red wire on a molex is only 5v you want to hook up the + to the 12v which is yellow
  3. Dholmblad
    29 Aug 2004
    Taht is what i did, sorry i didnt say that before.
  4. Go4t
    Go4t i
    13 Dec 2003
    maybe the fan is dead then
  5. kaptin
    kaptin What's a Dremel?
    27 Aug 2004
    It may of only been a 5v fan, the 12v you just put to it may have fried the motor....
  6. Dholmblad
    29 Aug 2004
    O well, i dont really care, just wanted to see if it would work.
