PSU PSU for new PC Build Advise
Discussion in 'Hardware' started by des011, 14 Oct 2014.
  1. des011
    des011 New Guy
    20 Dec 2010
    Hi Guys,
    We're looking to build a PC with the following specs, and would like to know the wattage required / can we get away with 600W
    Spec:
    CPU: i7 4790k
    GPU: Asus GTX 770 Direct CU II 2GB GDDR5 HDMI DVI DisplayPort PCI-E Grpahics Card
    Memory: AMD 16GB (2x8GB) Quad Channel Gamer (DDR3 2133/11.0/1.65v)
    MoBo:Gigabyte GA-Z97N-Gaming 5 Socket 1150 Mini ITX
    PSU: Corsair CXM 600W Semi Modular 80+ Bronze
    Thanks!
  2. GeorgeK
    18 Sep 2010
    I should have thought you'd be fine - the PSU is from a decent brand and has the connectors you'll need (it has 2 x 6+2 pin PCIE connectors and the 770 needs 1 8 pin and 1 6 pin)
  3. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    More than enough, no worries.
  4. des011
    des011 New Guy
    20 Dec 2010
    Great stuff, thanks very much for the quick replies!
  5. MrTeal
    MrTeal Member
    27 Aug 2010
    If you've already got the CX600M then there's no need to replace/change it. But if you haven't bought it yet then I would suggest taking the opportunity to find something else which is better quality. Chances are you won't even have to spend more money to do so.
  6. Refugee
    Refugee New Member
    25 Aug 2014
    That corsair should have enough power but remember that PSU's lose a small % of power over time.
    But can I just say that if you do replace it one brand to keep clear of is Thermaltake, their PSU's are sadly rubbish I've had 2 go in just less than 4 years.
  7. mrbungle
    20 Sep 2004
    With PSU's it isn't really the name its finding which oem makes which model if that makes sense.
  8. bartiszon
    bartiszon Active Member
    25 Aug 2010
    this:
    PSU Review Database
