Hardware PSU Group Test: 500W, 600W, 700W, 850W
Discussion in 'Article Discussion' started by Guest-16, 14 Sep 2009.
  1. Guest-16
    Guest-16 Guest
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    could you tell me how? they're all sourced from the same transformer..
  3. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Darn it :(
    I am waiting for someone to topple the crown of the BeQuiet 650w. I really want this PSU, but am struggling to afford £20 per 100w.
    PSU's seem one area in which the prices are going UP faster than inflation.
    My current PSU (Hiper 580w Type-R - which I have never had a problem with despite so-so reviews) cost less than £10 per 100w less than 3 years ago.
    Come on PSU manufacturers, give us a quiet, stable, cool PSU with oodles of spare power, modular cables and all in a nicely priced package! (Guess I AM asking for the impossible!)
  4. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Corsair HX-850 Cheesecake!... I read a review somewhere that they stretched it to 1064w and she didn't break... great PSU...
  5. Claave
    Claave You Rebel scum
    29 Nov 2008
    But at what temperature? PSUs lose the ability to output higher wattages as the internal components get hotter - Corsair rates its PSUs at 50C to give them decent tolerance, so possibly if the test room was 15C or something, the HX850 could output more than its rated wattage. Put it in a hot case though, and the maximum output will be more like the quoted 850W.
    Just worth bearing this in mind if you're building a PC - don't assume that you can get a cheaper, low-wattage unit an 'over-watt' it! :D
  6. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Cosair still seem to be producing brilliant PSUs, frankly I won't bother with PSU reviews unless something drastic changes, u simply cant go wrong with what COSAIR offer at the moment....just pick the right power range and your away.
  7. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    My HX1000 is perfect. Really can not fault it.
  8. V3ctor
    10 Dec 2008
    For what I saw... HX-850 is better... cooler, and efficient... stable... :) Can't put the link here, sorry :)
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I used to run 600w on my main.. but last year got a really good deal on a corsair tx850 single rail- the higher wattage is there if you need it, as long as you load it a bit- you'll run in the optimum range and get the best efficiency
    that's why I think going higher than what you need is the best case scenario.. if you get a ps that's just enough to cover what you have running, it will have high heat, lower efficiency, need more fan
    on the other end.. if you go too high, like 1000 watts and only running a emachine.. the ripple is worse
  10. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    I've been using a corsair tx650 for most of a year now. It's very similar in many respects to the 850 model, but it's definitely not noisy (pushes out hot air, though). I'd definitely recommend it if 850W isn't required and you can fit all those cables in your case.
  11. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    as its what i can realy only get on my list i use thermaltake thoughpower PSUs (min is 750w they start from purepower is below that) never realy had an problem with them i had 1-2 1000w PSUs powering 3x9800GX2 (folding) as it has native 6PCI-e power connectors and the 1500w one is perfect for 4GPU systems as that has 8PCI-e power, i would like to see some of thermal take lower end PSUs reviewed
    i nom get 500w cheap octigen (most likey blow up at 300w load ) but they do as replacemets as most of them norm pull max 100-150W in the systems
    and for better tests realy you should of been doing 75% load tests as well or something like HardOCP PSU tests
  12. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Earlier this year I bought a Be Quiet DarkPower Pro 750W... a little on the expensive side, but you get what you pay for. I'm just hoping these tests vindicate my purchase....
  13. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I love all my Corsair PSUs. Never had a problem with any of them (knock on wood.).
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I have the Nexus NX-8060 in my brothers rig and it is simply amazing, silent, clean, just works. Certainly would recommend that PSU for people needing a PSU in that power range.
  15. adidan
    25 Mar 2009
    Be Quiet Dark Power Pros Cheesecake. In my experience no other range comes close for stability, build and quietness.
  16. -Acid-
    -Acid- What's a Dremel?
    10 Nov 2004
    Suprised that the Enermax Revolution 85+ 850w+ isn't here seeing that at the minute it curently is the best power supply doing the rounds with 91% efficienty.
    I see you reviewed the 950w version and loved it
    I,m looking for a new psu as my last one died, dammed 2900xt's suck loads of juice at 1.35v core each.
  17. Guest-16
    Guest-16 Guest
    Pretty much the same thing to be honest. 850.. 950..
Tags: Add Tags
