PSU PSU help
Discussion in 'Hardware' started by tomtomk, 20 Nov 2010.
  1. tomtomk
    tomtomk What's a Dremel?
    27 Oct 2010
    Hi guys i've recently upgraded my pc thanks to the help of some ppl on here but i have a feeling my psu is not up to scratch as I am getting unplayable fps in COD: BO and other games such as WoW arent really running as smoothly as i'd like them to.
    basicly im just looking for the best PSU for around £50 , i am not looking to get SLI for my card btw.
    not sure if i need to supply more specs than just my graphics card and processor so if I do just let me know, thanks in advance. Tom.
    specs:
    1gb gtx460
    intel core 2 duo e4600 2.4ghz
    460W coolermaster PSU
    4GB RAM
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I would of thought your PSU should be fine. Had it for long?
  3. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    I would say your PSU definitely isn't an issue, 460W should be plenty for what you have listed.
    How much RAM do you have? Have you considered overclocking your CPU at all? What res are you playing at?
  4. tomtomk
    27 Oct 2010
    its over 2-3 years old and it says that its only 310w when its 12v
    I have 4gb ram
    and I wouldnt consider overclocking my cpu as I think the psu is the problem
    oh and im only playing at 1280x1024 as my screen is pretty bad so thats why im thinking my fps should be considerably higher!
    cheers for the quick reply guys :)
  5. GoodBytes
    20 Jan 2007
    It smells like a driver issue... a chipset OR GPU driver issue OR your CPU or GPU throttles due to overheating.
    If it was the PSU, then the system would just turn off on it self as soon as you stress the system.
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    ^^ This. Are you on Win7? If so, did you let windows select and install the gpu driver for you? I always download the driver from the manufacturer of the card.
    What case do you have? How is the cooling?
  7. tomtomk
    27 Oct 2010
    to tell you the truth I just formated my pc and installed windows 7 yesterday so I havnt actually tested any games since. ill check to see if its still lagging and get back to you guys cause it could have possibly been a driver issue as i switched from an ati card to an nvidia while i was still running vista and im not sure if i deleted the previous gpu driver properly.
    cheers ill be very happy if its not a psu problem :)
  8. Jipa
    5 Feb 2004
    If the PSU provides what it promises, it's not an issue. And if it were, you'd most likely get crashing and/or smoke, not just poor FPS. (I've used a 320 W on 12 V line to run more power hungry stuff than that) Also dunno about WoW as I've never played it, but I can tell I get poor FPS in CoD:BO with HD5870 and a 3,5 GHz quad-core...
    So try re-installing all the drivers before shopping anything new.
    EDIT: damn ninja'd :)
  9. Bloody_Pete
    11 Aug 2008
    Maybe your heatsinks need a hoover...
  10. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    I'd suggest using driversweeper beforehand to help clean the slate.
  11. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    PSU would not be my first port of call if I had the same issues.
    I don't like CoolerMaster PSU's or at least the 1 I tried, but I wouldn't say that was your problem.
    Suggest taking wise suggestions above.
  12. tomtomk
    27 Oct 2010
    hey well to my surprise when I booted up my pc this morning i got a CPU error and had a look inside my case and it seems my cooler is broken so have changed it back to the stock one that came with the processor.
    hopefully this was the only problem but im really not sure why it stopped working but thanks for all the help guys you never dissapoint :)
