Electronics PSU input
Discussion in 'Modding' started by beastnburger, 11 Oct 2004.
  1. beastnburger
    beastnburger What's a Dremel?
    18 Aug 2004
    I need to route the PSU input to another location, how would i go about doing this? BTW i dunno if this is the right thread.
  2. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    Maybe explain what you want to do? I don't know.
  3. beastnburger
    18 Aug 2004
    well, i have a shuttle and im putting a black ice xtreme on the back and the psu input is getting in the way so i need to route it to a different location, is there a way to do this?
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    You can either take the PSU apart and route the plug-in to another part by extending the wires or soldier two wires(or crimp) from the socket to another socket.
  5. beastnburger
    18 Aug 2004
    I guess ill just extend it
  6. beastnburger
    18 Aug 2004
    is there any way I can eliminate mobo ports? do i just solder them off? also can i move some of the ports around by adding wire extensions?
  7. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    uhh no. i wouldent take anythign off the mobo unless you realy want to kill your computer. well you can try, but with out a decent SM iron and with no knowlage of what the parts do you have a .01% chance of success.
    as for the ports...
    ps2, usb, network, sound, video ~ yes, but be very carfull. you are working very close to VERY important stuff
    PCI, AGP, prossesor socket, ram ~ no. dont even think about it. hundreds of very very small pins, plus latency would be a royal biach, slowing your computer down to a 386...
    internal sound patch, LED headers, smalls stuff ~ yes, but be carfull!
    its a much better idea to find the propper extention cable, and use that
    if youve never done SM before, i would highly reccomend agienst soldering ANYTHIGN on your mobo
  8. Risky
    Risky Modder
    10 Sep 2001
  9. beastnburger
    18 Aug 2004
    umm no definitely dont wanna move cpu, ram, vid card, but thay answers me question
  10. beastnburger
    18 Aug 2004
    New question, i bought some RBG LEDs that instead of having 4 prongs (one red, one green, one blue, one ground) it has 6 prongs. i think the two are for red, two are for blue, and two are for green. if this is the case, would there be a positive one and a negative one? or can i just have the two prongs go to one wire?
  11. theshadow27
    23 Sep 2004
  12. beastnburger
    18 Aug 2004
    wow, complicated, how would i go about wiring that?
  13. theshadow27
    23 Sep 2004
    its not realy complicated... you wire the anodes to + and the cathodes to -. not hard at all :duh:
  14. beastnburger
    18 Aug 2004
    its just i was planning on using a LED with 3 stubs (R,B,G) so where would the cathode and anode stubs be wired to?
