this is my up coming mod bought 4 male and 4 female and pins molex connectors of ebay for 8.88. this is the PSU i am using but no window and the wires are not sleaved. I might add a window to it but wouldn't be able to see the PSU window cause the part side and top panel covers it up tonight i am sanding,primering, and painting it gloss black. tommrow will add couple more coats of black and the few coats of clear coat.
I have found some crome bio hazzard fan grills i will be adding. I realy don't like the 80mm fan sitcking out side of the PSU between the ROMs but what to do?
maby hot glue? anyways, thats great. I was going to do one of those but I have no tools for crimping or spare wires to chop and put my blue molexs on. overall looks very clean, nice job.
I wanna do something like this! Great work Now I just need a new PSU, after Mine broke randomly My first post here I post on KustomPc's as 'haz' I thought I'd finally register, I have been a long time lurker. Any chance of some pics of the PSU with the cover off? So we can see what you've done on the inside.. cheers.
If I can find some female molexes locally I would also like to attempt this. Looks VERY shiny. Good job.
Thanx everyone i used epoxy glue to keep the molex's in place. As of the molex connectors i got a deal of ebay for 4 males and 4 females white for 8.88 with the pins. sorry i can't get inside pics its already in my computer and i used the digi camra at work no chance of bringing it home.
Is that enough lines there? I think I might do the same to my case... I would love a nice xconnect PSU as is advertised up there ^ but I have better things to spend the cash on. -J
