Small Form Factor PSU on its way out?
Discussion in 'Hardware' started by hellomoto, 5 Apr 2005.
  1. hellomoto
    hellomoto What's a Dremel?
    4 Sep 2003
    My SN85G4 shuttle's PSU is quite hot, do you think its on its way out?
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    No, it isn't, my SN85G4's PSU get's quite warm. It's normal. :)
    R.
  3. hellomoto
    4 Sep 2003
    OK thanks.
    It's just quite hot.
  4. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Does it burn you, when touching the case? or just very warm?
  5. hellomoto
    4 Sep 2003
    The PSU case doesn't burn. But it is quite warm. After having the shuttle for more than a year, the fan had to be put up higher. I've even added an additional 80MM fan at the back and cleared everything from dusk.
    Its just most of the heat comes from the PSU, and it is alot of heat. I now have to keep the case off completely.
  6. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Unless you are experience problems with stability, you should be fine. The Shuttle PSUs do run quite hot.
  7. hellomoto
    4 Sep 2003
    I've checked the temps and system temp is 60 and cpu temp is around 55. The PSU is very very hot to touch now.
  8. WTF_Shelley
    WTF_Shelley The picture is wheeljack
    6 Apr 2005
    It sounds a little worring, Tried emailing the manufactor for Temps. If you have to take the case cover off for it to run, that sh*t aint right.
  9. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    It should be fine , they run quite hot, it has a 60mm fan in there keeping it cool :)
  10. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    If it is the normal temp as others it should be ok but if you are running it with the case off i suggest replacing it.
