Modding PSU Pin Removal
Discussion in 'Modding' started by Leeum, 7 Jun 2004.
  1. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Hi Guys,
    Going to be sleeving my PSU soon and don't want to pay £10 for a tool i will possibly never use again. I can remove the pins from the Floppy and AUX connectors but can't remove them from the others. Any help appreciated :D
    Thanks
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    i think you might find something if u :search: . Apologies if you don't!
  3. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    use this
  4. Leeum
    16 Feb 2004
    The problem is removing the wires :duh: Can anyone help?
  5. JoyRider
    JoyRider What's a Dremel?
    7 Jun 2004
    ...you can use a tiny screwdriver or a needle.
    See, take the molex wire for example. The plug of each wire looks like a wood plug with wings where you screw your screws into. But it's metal =o.....so get your needle between the inside casing of the molex and the wing and push it back in, to that to all other wings of that wire. When you're done, pull at the wire (a lil' bit of strength is ok, but not too much)
    an other but ingenious (taken from a Tweakers member) way is to use the hollow connector of an ear headphone. Just push the plug into the connector and pull it out.
  6. Nexxo
    23 Oct 2001
    Since you're not having any joy, and KustomPC is currently out of stock, if you e-mail me your home address I'll lend you mine.
    (And don't y'all go asking for my tools now, y'hear? This is a one-off favour. :D )
