Electronics PSU size?
Discussion in 'Modding' started by Furball Zen, 4 Mar 2013.
  1. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    So i successfully swapped my XPSP3 email box to an SSD using an IDE to SSD convertor. Please dont ask why i dont just upgrade the hardware, i wont.
    My question is this: i only have a 1.2G Celeron PIII based proc, a single 60MM CPU fan and the OS SSD. Ive been told the max the CPU can draw is 30W and the fan/SSD would be negligible. The mobo is a Gateway mATX Intel 915 series with on board video, but i only access it via RDP.
    Currently i have a Thermaltake 430W PSU on it and i know its overkill. Most SFX PUS's are way more than i want to spend, so im wondering if i can get away with a smaller PSU around 75W or even a pico PSU with a wall wart.
    Any ideas?
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    picoPSU will be enough, if you don't use a dedicated GPU, but the price for these is $80 aswell (picoPSU + powerbrick) so a SFX-PSU for $60 is a good option.
    Furball Zen likes this.
  3. Guest-23315
    Guest-23315 Guest
    What he said.
  4. Furball Zen
    25 Jan 2012
  5. Guest-23315
    Guest-23315 Guest
    Should do. Take it your motherboard needs a 20 pin not a 24 pin then?
    I didn't realise you could get them that cheaply!
  6. Furball Zen
    25 Jan 2012
    Yea, i figured the PIII equiv would have tipped that off :)
    Sorry, its an 815 not 915 lol.
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Yeah, this should work. The Celeron PIII 1.2GHz draws a max of 31 Watts according to ark.intel and as it's an old PPGA370 it should have a 20-pin ATX-connector aswell.
  8. Furball Zen
    25 Jan 2012
    Yea i thought so, but the PSU Calc page said i would draw around 100w which seemed really high considering i think it came with a 70w from Gateway.
  9. exiled
    exiled What's a Dremel?
    17 Jul 2012
    id suggest buying a 120watt picto psu just in case you plan on adding more hard drives
  10. Furball Zen
    25 Jan 2012
    Pffft lol. I just downsized from an 80gig IDE to 40 gig SSD... it ONLY does email.
  11. Furball Zen
    25 Jan 2012
    Just wanted to update this, the pico is installed and running fine :)
  12. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    photo's?
