PSU PSU with Braided cables
Discussion in 'Hardware' started by Pootana, 6 May 2015.
  1. Pootana
    Pootana New Member
    1 Feb 2004
    Can somebody recommend a PSU that comes with braided cables as standard or do I need to buy after market ones ?
    psu required to power a 970 GPU card.
    ta
    Poot
  2. SuperHans123
    SuperHans123 Well-Known Member
    27 Dec 2013
    What are the rest of your system specs?
    This will help in suggesting an appropriate PSU.
  3. Pootana
    Pootana New Member
    1 Feb 2004
    At moment
    As rock 890 mono
    Amd 960 cpu
    1tb WD hdd
    970 nvidia
    The gpu at moment is a 550ti but I need a new psu as lost a cable that would allow the 970 to go in the system
  4. SuperHans123
    27 Dec 2013
    You can buy cables separately.
    What PSU do you currently have? It may be good enough.
  5. Pootana
    Pootana New Member
    1 Feb 2004
    It's a Jeantech 500w but I am missing a cable to get the 970 working. So basically I am going to flip over to a Intel system. So gradually improve the components.
  6. SuperHans123
    27 Dec 2013
  7. Pootana
    Pootana New Member
    1 Feb 2004
    Hadn't really put an exact figure. Just wanted a source that was future proof for few years and had braided cables for management looks reasons.
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  9. Big Elf
    23 Apr 2009
    BitFenix have the best sleeving I've seen from a mainstream manufacturer, good quality and robust. I normally sleeve my own stuff but I have used their cables in the past.
    By the way, this is a braided cable:
    The sleeve on it is braided.
  10. The Infamous Mr D
    The Infamous Mr D Member
    11 Feb 2008
    I'd seen these and would really like to use them. Ideally, a PSU which you can plug these cables directly into. The Seasonic M12 that supermuchurios recommended (like most of the modular PSUs I've seen & worked with) looks like it has proprietary connectors for its cables.
    Does anyone know of a solid PSU which has connectors suitable for the Bitfenix extension cables?
  11. Big Elf
    23 Apr 2009
    No PSU will allow the use of extension cables plugged directly into it, they all have male connectors at that end.
  12. The Infamous Mr D
    11 Feb 2008
    Bugger, that is a bloody good point. Well, that's that idea out the window then :p
  13. Big Elf
    23 Apr 2009
    If you're prepared to pay the cost you could buy a modular PSU of your choice and then get someone to make up a set of sleeved cables for it. That way you get your choice of colours and materials. It won't be cheap for a quality job though.
  14. Pootana
    Pootana New Member
    1 Feb 2004
    So do any companies have braided cables that aren't just extenders
  15. Blogins
    3 Aug 2010
    Corsair do for particular PSU models but the quality is rubbish compared to Bit-Fenix.
  16. Pootana
    Pootana New Member
    1 Feb 2004
    Do the bit fenix cables only fit their psu
