Modding PSU's and overloading
Discussion in 'Modding' started by GiGo, 13 May 2002.
  1. GiGo
    GiGo was once a nerd.....
    12 May 2002
    I was wondering i've got a 300w PSU and it only came with 3 connectors, 2 with 3 1/2 adapters. I've got the 2 HDD's, 2 DVD's, the Live Drive and 2 fans.
    What can PSU take?
    and also how hot should they get?
  2. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Well i would say if your running an athlon setup that your getting close to the limits of that PS. Even though they are pricey, a quality 420w is always a good investment.
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    use motherboard monitor to monitor the voltages and see if any off the voltages ae really low then you know that you have to much running off of the psu.
  4. GiGo
    12 May 2002
    Cheers
    I added an old SCSI 5 1/4 PSU this morning to run the fans, Dremmel's are good but Hacksaws really kick @$$.
    Does any one think it was a bad idea to add it or not? It's only going to run 2 80mm fans (doing that now). Maybe a 120mm fan (running @ 12v) and 2 90mm fans? I'm a bit concerned it that the PSU's are hot. The idea behind the old SCSI PSU was I can turn all but the CPU, Gcard and Co-Processor off at night if the system isn't in use.
    Can anyone think off another way to powerdown the fans or another mod to powerdown the fans?
