psy^tx1050b - Project Worklog
Discussion in 'Project Logs' started by psynapse, 29 Jun 2005.
  1. MonkeySpank
    MonkeySpank Banned
    10 Aug 2005
    Lovely Bondo job and looks very good. Nice painting on the fans aswell. :thumb:
  2. psynapse
    psynapse What's a Dremel?
    29 Jun 2005
    Hehe yeah, maybe i should give it a light sanding to smooth it back.
    You can't see the "meltedness" under UV, but my cameraphone just doesn't do it justice at the moment.
  3. psynapse
    29 Jun 2005
    Few more pics guys.
    Just realised you can't really tell what i've done with the SATA cables in the previous ones, so let me walk you through it :)
    Both cables are tucked into in a single piece of cable sleeving, with the plugs shrunk as close to together as possible.
    Which runs down under the AGP slot, next to the chipset heatsink.
    Out on an angle when it hits the floor of the case.
    And branches out to plug into both drives.
  4. Uno1_
    Uno1_ What's a Dremel?
    14 Nov 2003
    Nice trick with the SATA.
  5. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Great bondo and paint job on the front panel psynapse. I also really like the sleeving and cable management, really neat. Well done.
  6. TMM
    TMM Modder
    12 Jan 2004
    How hot does the chipset run?. Certainly looks like it melted :D :p
  7. psynapse
    29 Jun 2005
    Haha :hehe:
    With 1.9v through it, it rarely goes over 30°c.
    With the stock chipset heatsink on this DFI nf3 ut250GB it was pushing over 50°c :jawdrop:
  8. Jipa
    5 Feb 2004
    I should do something like that with my mobo and graphiccard, original solution is just too noisy and unefficient :(
  9. Bluefan
    Bluefan test 123
    25 Feb 2005
    reminds me of some asus stock NB heatsinks, very tiny heatsinks with an even smaller 8k-9k rpm noisy fan on it. Just crazyness if you're NOT replacing that ones :D
