Scratch Build – In Progress Puddidium235 - 1-18-21- the FOLD in Manifold
Discussion in 'Project Logs' started by Cheapskate, 13 Nov 2019.
  1. Cheapskate
    13 May 2007
    -Well, that was...different. I just hope it's over.
    I have 2 houses I still need to turn the water back on to see what happens. I have one tenant that flooded the kitchen and living room because they didn't know what the faucet knob on the side of the house was for, Another that turned his water off as soon as he noticed the burst pipe, and the other tenants are still silent. :worried:
    -I'm pretty sure those were the only copper pipe houses. The big problem is that the hardware stores all had F'all for plumbing stock a week ago when I went, and now they are lined up for a block...and probably still don't have plumbing supplies. [/rant]
    Anyway, I'm exhausted and I needed someone to rage to. Everyone else I know is in a similar boat... just not times 12.
    Edit: 2 more breaks. One blew out my Aunt's kitchen ceiling. :(
  2. kim
    kim hardware addict
    10 Jan 2016
    Nothing worst than plumbing issues, even for the master of water-cooling :naughty:
  3. Nexaner7
    Nexaner7 What's a Dremel?
    4 Feb 2021
    Looks like the marble runs I used to have as a kid ^^
  4. Cheapskate
    13 May 2007
    @kim - Sucking up an inch of water with a shop vac and pulling up laminate while the tenants play with their phones, then spending the next day crawling through their attic to pull wet insulation. -Not much plumbing. :(
    @Nexaner7 - Talking about runs with only a toilet on the page. :lol: What?
    Resting. I guess I should post the tiny amount of update I have:
    -I did the top pass on the chunk. This involved zeroing the machine on the top corner hole. Then the holes were bored out to fit screw heads about 3/4" deep. Here it's making a slot for that front cap I started with.
    -I got the switch assembly fitted. You can sort-of see a 1/4" round peg of swirl plastic glued to the switch. It's cut to the height needed to trigger the switch when the marble is pressed. I tested it, so 3 years from now when I actually get to use it, it should work.
    -I managed to find some screws long enough to test fit the two manifolds. At this point I had stopped to draw stuff for MNPCTech, and then this ice-storm thing happened.
    See you in Spring?
  5. Nexaner7
    4 Feb 2021
    I am a little late to the party, but it was referred to the first few pages :grin:
  6. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Got some serious weight in acrylic in this build! Just thought regarding the rough surface on the milling, its not the direction of travel of the milling is it? I find it cuts cleaner in a particular direction for each side.
  7. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Always love a good acrylic milling build but this is going overboard!
    Awesome, hope the ice storm didnt cause to much damage.
  8. Cheapskate
    13 May 2007
    Thanks. :D
    Amazon has middle of March delivery times for plumbing stuff, a $4 can of pvc glue is running $20, and there's no drywall anywhere. Yeah, there was damage. I need about 15 sheets of drywall. Thank God were are friends with a flooring company owner.
    @riekmaharg2 - I confirmed the smooth-rough was due to a tiny tilt. Where it chewed up only part of one side, though? :worried:
    @Nexaner7 - Just teasing. :D
