Cooling Pug: watercooled PSUs
Discussion in 'Hardware' started by SpeedFreak, 14 Jun 2003.
  1. Risky
    Risky Modder
    10 Sep 2001
    So any leaks don't drip on the electronics? Seems sensible enough.
  2. k.a.
    k.a. What's a Dremel?
    4 Jun 2003
    if the leak is inside the PSU ... bad. but the connections them selfe could be outside the PSU but inside the case...
  3. DeX
    DeX Mube Codder
    22 Jul 2002
    If you expect the connectors to leak why would you have water cooling in the firstplace? you can't get awaying with putting the CPU block outside the case so why bother with the PSU?
  4. Pug
    Pug What's a Heatsink?
    16 May 2002
    Hmm, it seems AC have them too. :)
    I just ordered one, so I'll let you know what it's like when it gets here.
  5. sganimefan
    sganimefan What's a Dremel?
    24 Mar 2003
    Hm... Why's the 350W PSU cheaper than the 250W version by 60 Euros? :confused:
  6. Fatboy
    Fatboy Bored
    8 Oct 2001
    maybe cos its in a standard case and stuff, the 250 is very high quality by the sounds of it and its got a custom enclusure and anodized bits.
  7. Pug
    16 May 2002
    Well, after what seemed like an age, the CoolCurrent finally turned up this afternoon.
    As Fatboy said, it doesn't quiet have the same allure (or bling factor) as the AquaPower.
    The thing I wanted to check out which I think also counts for part of the price difference was whether it had the inbuilt relay feed.
    It doesn't, so there's another good reason for it to be cheaper.
    Also, the AquaPower is autosensing on the input voltage and so will accept any input voltage from 100V - 240V, 50 - 60Hz.
    This one is 230Volt only.
    Specs from the label for the curious
  8. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    If its a 350W PSU why is the total 197W ? :confused:
  9. Pug
    16 May 2002
    The 350Watt quoted is Peak, as with most PSUs.
    [Edit] The 197W is sustained (think RMS vs PMPO with stereos)
