Case Mod - Complete #Pure sponsored by Thermaltake and MSI
Discussion in 'Project Logs' started by AML_customs_pc, 26 Mar 2019.
  1. AML_customs_pc
    AML_customs_pc Member
    24 Feb 2017
  2. AML_customs_pc
    24 Feb 2017
    Hey, hope everyone had a good weekend.
    So this is the case,
    I remove psu cover and motherboard tray.
    I made a model out of cardboard to make sure I got the correct sizes for the perplex
    After I did this I removed the IO shield and graphics card supports from the back of the case so I can move this to the top of the case.
    Once I cut the case up I new I would need to replace the back of the case, I made a quick design on fusion 360 and made a new back panel, this will include displayport and 2 usb 3.0.
    I chopped down an old bracket for the thermaltake p3 to help support the graphics cards so it can hang down in the case.
    This is the point I needed to stop as I needed to pick up the perplex for the next stage of the project.
    This is where we are up to.
    arduum likes this.
  3. AML_customs_pc
    24 Feb 2017
    This week I made the the custom motherboard tray with built in res, I used 10mm acrylic to do this.
    the start of the motherboard tray.
    Making the motherboard res.
    Test fit with the motherboard.
    Need to add the custom o-rings
    Wanted to see what the water manifold would look like with some water in.
    I will be down I64 this weekend so this is where I will stop for this week. You can see its starting to take shape.
    next post we should have the cables the covers and the tubes ran.
    Cheapskate, Lambda and arduum like this.
  4. AML_customs_pc
    24 Feb 2017
