Scratch Build – In Progress purple-haze (as named by ediejo!!) update 5/11/2007 watercooling parts!!
Discussion in 'Project Logs' started by x06jsp, 29 May 2007.
  1. fungry
    fungry What's a Dremel?
    14 May 2006
    haha, looks like ill be spending my time browsing around for buttons too :D
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    lol! klkl the ones most people use are bulgin vandal resistant switches but for £15 each they are not worth it!!!
  3. fungry
    14 May 2006
    dude seroiusly, 15 pounds makes me laugh so much.
    15 pounds for a button lmao
  4. x06jsp
    2 Apr 2007
    lol yer they look good but they are not worth it!!
  5. fungry
    14 May 2006
    lol, if i'm right that is over 200rmb just for a button. heh.
    i'll probably find one for 10-20rmb and just buy it. as long it looks basic in a good way and that it works.
  6. x06jsp
    2 Apr 2007
    lol!!! klkl
  7. Teyber
    Teyber ******
    18 Mar 2007
    updates?
  8. x06jsp
    2 Apr 2007
    one will hopefully be on the way tomorrow evening! so stay tuned!!
  9. x06jsp
    2 Apr 2007
    hey people sorry no update today the alu and acrylic arrived too late o do any modding but tomorrow i will hopefully be able to show you the hdd cage as i have from like 8am-3pm to mod :thumb:
  10. fungry
    14 May 2006
    haha just got home. checked out the prices of cases and the likes, pretty expensive over here. heavily taxed. hopefully sometime end of this week, i will be paying a visit to B&Q.
    looking forward to that update :)
  11. x06jsp
    2 Apr 2007
    klkl yer get yourself some materials!!!!
  12. x06jsp
    2 Apr 2007
  13. fungry
    14 May 2006
    rights! i went to b&q today, and they dont' have what i wanted.
    so my alternative i think is to get a power drill + jigsaw seperately. they are actually cheaper then expected.
    the powerdrill i can purchase in a toolbox set, comes with a metal ruler, wrenches, allen keys and much more.
    as for the jigsaw, its only a single speed jigsaw which comes with a pair of standard blades.
    both of them that i plan on purchasing will be manufactured by black and decker.
  14. x06jsp
    2 Apr 2007
    yer if they dont have a 'dremel' then yer id say go for it black and decker are good so no need to worry about quality! lol
    i will have an update later today im currently working on the hdd cage.:thumb:
  15. fungry
    14 May 2006
    yea, will have to do it that way. pity i reckon.
    nonetheless, still waiting for that update! :)
  16. x06jsp
    2 Apr 2007
    yer itll b here later :thumb:
  17. x06jsp
    2 Apr 2007
    well it didnt quite go to plan today and i didnt like teh way that the hdd cage was going so i am going to start again on it tomorrow! o well
    so ill cya tomorrow:thumb:
  18. fungry
    14 May 2006
    aiya!~ well i suppose you learnt something right? that is what matters.
    anyways, i'm actually pretty loss in terms of rivets after going to bnq today...
    so computer screws tend to be m3 right? so i drill a 3mm hole right? but what size rivet do i use? 3mm right? because when i went to bnq today, they didn't even sell 3mm rivets, instead they had like 3.2, 4, 5mm and so on. no 3mm in sight.
    also what about thickness. for example, say if i am riveting two sheets of al that are 2mm thick each, therefore 4mm in total, do i have to use a rivet that is 4 mm in length or can i use something like... 7mm?
    thank you so much! how life is confusing when you are not knowledgeable
  19. x06jsp
    2 Apr 2007
    well no ive been using 2.4mm and 3.2mm rivets! lol
    ummm length not sure ive been using short lol
  20. fungry
    14 May 2006
    2.4mm for what size holes
    and 3.2mm for what size holes?
    i am guessing, your using 3mm drill and using 3.2 rivets? :S
