Mod of the Month Purple Pill Fractal Define R6 Build :)
Discussion in 'Project Logs' started by CustomRigs, 28 Mar 2018.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Finished "The Purple Pill"
    I hope you like it [​IMG]:) i designed my first distributionplate and has a lot of trouble with it. But finally [​IMG];) the trouble was worth it.
    Specs to the System:
    Fractal Design Define R6
    Custom Made Distributionplate CNC Milled by NTG
    Intel I7 8700K
    AORUS Z370 Gaming 7 Mainboard
    16GB DDR4 Patriot Viper LED Ram
    GIGABYTE GTX 1080ti Founders Edition
    240GB Patriot Burst SATA SSD
    250GB Samsung 960 EVO M.2 NVME SSD
    Inter-Tech SAMA Forza 1200W PSU
    all fans are from Noiseblocker six 120mm and one 140mm eloop B12/14-PS
    Custom Cable extensions from Arcturos Solutions
    Watercoolingparts:
    Watercool Heatkiller IV CPU Cooler with a black mountingkit
    Watercool Heatkiller IV GPU Block
    Watercool Heatkiller Tube 100 with DDC Pump inside
    two 360mm radiators (Magicool and Barrow)
    16mm Barrow Hardtube Fittings
    16/12mm Acryl Hardtubes
    some extensions and angles ...
  2. CustomRigs
    8 Dec 2017
  3. CustomRigs
    8 Dec 2017
  4. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Really like how well the 'distro plate' worked out. The loop is striking, good work. Loving the GPU mounted orientation, nicely shows off the block. Great to see some Heat Killer gear too!
    J.
    CustomRigs likes this.
  5. TheMadDutchDude
    23 Aug 2013
    That’s a totally different design from the norm. I really like what you’ve done! :)
  6. CustomRigs
    8 Dec 2017
    Thanks alot guys !! Really happy that you like it ... yes normal is boring the heatkiller components are great ! U feel it in your hands ... high quality and made in germany :)
    With the tubes im not 100% satisfied but it is okay :D ... next project has started ;) parvum systems r1.0 ATX
  7. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Really nice mod dude, that distro plate is sweet :thumb:
  8. CustomRigs
    8 Dec 2017
