Electronics Push Button Switch (12v)
Discussion in 'Modding' started by BlueMax, 14 Aug 2003.
  1. BlueMax
    BlueMax What's a Dremel?
    23 Mar 2003
    I bought this switch, hoping I could rig it up to work for my neon cathode in my computer. The neon cathode has a red and a black wire coming out of the transformer for a switch. The push button switch has a red, black, and white wire coming out of it. It says the white wire is for a relay in a 12v system, but is there anyway I can wire it up to the cathode anyway? (I suck at electronics, so complex diagrams and stuff are useless :naughty: )
    My main question is, can you straight wire it without any transformers or relays or anything? A push button cathode would be awesome :rock:
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    You can, but then you would have to hold the button in to make the cathode stay on...
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    a d-flip-flop thould be noce for what you need.. pretty easy to wire up aswell.. :)
  4. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    A Flip-Flop you say?:
    Replace the wore FAN with COLD CATHODE CIRCUIT and that should work.
  5. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    dont u wanna clamp that relay with a diode?
  6. acrimonious
    8 Nov 2002
    :duh: damn must have forgotten abotu that when i put this diagram together, TIP's are pretty tough but it would b a very good idea yes.
  7. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    What other transistors would work as well? Any NPN?
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Any NPN that will carry the relay coil current. A 2N2222 (600mA) should drive 99% of relays, 2N3904 will drive small ones up to 200mA.
    I'd also add a 470R base resistor to limit current drawn from the flip-flop, and you need to ground inputs on the other half of the 4013.
    With no switch debounce components you'll get a few false triggers. :sigh:
