Cooling Putting 2 fans on rad improves performance
Discussion in 'Hardware' started by JonDixon, 29 Aug 2003.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Okay,
    Ive just replaced my 120mm ys-tech fan (the biggie with 105cfm)
    to 2 120mm evercools which both together seem as quiet as the ys-tech.
    Now Ive seen a 6'C drop in temp on my CPU from 38'C to 32'C and my system temp has dropped from 48'C to 40'C
    Now if only I knew how to overclock
  2. Risky
    Risky Modder
    10 Sep 2001
    I'll guess that's one each side. Do you know the cfm on the Evercools?
  3. JonDixon
    12 Mar 2002
    Just looked it up the cfm is 79.14 the rpm is 2000
  4. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    i've often woundered this also i've got loads of pairs of fans
    I was gonna put a couple of the Aluminum papst on my rad see if it did anything but am not sure is there anyproot that it works ??
  5. Risky
    Risky Modder
    10 Sep 2001
    I'd like to do this but my two 120mm Fans are mismatched and a pair of new Papsts is a bit of a scary purchase.
  6. JonDixon
    12 Mar 2002
    These evercools seem quite good. They were only £5 each (they came with 3pins and a converter to make them 4) with p&p free.
    http://www.thecoolingshop.co.uk/tcs/comersus_viewitem.asp?idproduct=16
    Running them on my Noise Isolator fan controller on lowest setting.
    Ive bought panaflo's in the past but for the extra money I didnt find them that much quieter.
  7. Risky
    Risky Modder
    10 Sep 2001
    I suppose that is about 75% less than the Papsts but I've got a bit of a hangup on fans.
    Whats the noise like when you drop the voltage on them?
  8. JonDixon
    12 Mar 2002
    cant hear them over my psu
  9. Risky
    Risky Modder
    10 Sep 2001
  10. EnderG60
    EnderG60 What's a Dremel?
    20 Aug 2003
    I have 2 big loud 120mm fans one on either side of my rad. with some shielding for a nice wind tunnel effect works ALOT better then just one
    if i want it quite i switch them to 5v or 7v and they do a good job for cooling at low system loads, and switch em back to 12 for high loads
    unless your rad is mounted to the top of the case with one fan onthe bottom blowing up....you should always have 2(one on either side) on it...it just works better
  11. J13ntv
    J13ntv What's a Dremel?
    30 Aug 2003
    I was wondering, Do you have to put two shrouds then I assume, one on the front and one on the back, or you could have them hugging the rad but that doesn't seem to give the best flow. NOw what happens if your rad can hold 4 fans (like the BIX2) You need four shrouds??? :)
  12. Blackeagle
    Blackeagle What's a Dremel?
    1 Nov 2002
    Nah, just two shrouds set up to take two 120mm each. Now that is a extreme water cooling set up.
    But would handle TEC's or whatever pretty well.
    Anyone interested in a quad of 120mm Delta 130cfm fans on a really large heater core?
