PVC Desk
Discussion in 'General' started by wsurritte, 11 May 2006.
  1. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    what do you guys think of building a computer desk from 1 1/4" pvc pipe?
    i would use 3/8" mdf for the top, and an under desk cpu tower holder
    WILL
  2. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    I think it will look like white trash. Post pictures when you finish.
  3. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    if your planning on making a desk out of mdf and plasic tubing you seriously need to question both your design and ergonomics skills
  4. keir
    keir S p i t F i r e
    5 Oct 2003
    it would like pretty crap imo, but go for it.
  5. chemo
    chemo True Jungle Brother
    20 Feb 2005
    give it a go and do a log of it all. it could turn out quite good, cant really get any idea of what it will look like by looking at your explanation, prove the above wrong :rock:
  6. Monkeyboy
    Monkeyboy Minimodder
    13 Dec 2003
    do it, i dare you!
    and post any and all pics
  7. wsurritte
    31 Oct 2005
    thanks for support, but im wondering if (even if properly cemented) the joints would be loose. btw the main part of the pvc is for the frame. thiers alot of pics on : http://www.pvcworkshop.com/ but i think i can make my desk look way better than thiers.
  8. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Heres a pic of the entertinment center my brother built just before leaving for uni a couple of years ago. Made out of 3/4" plywood, 1 1/4" pvc and threaded rod. Works / worked great (Hes still using it 4 years later) and it dissasembled completely flat to fit in the back of his car. And to top it all of it dosent look that bad.
    Hope that helped
  9. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    pvc can be pretty strong when properly glued. certainly strong enough for a desk.
    the one issue is that it willl most likely turn out looking like ****... something like tm36 is probably the only even decent looking way to do it...
  10. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    give it a shot
  11. Pookeyhead
    30 Jan 2004
    Very strong vertically, but laterally can be quite wobbly if not braced in many places. I did something similar once. It looked awful as well. Post pics when you're done tho... prove us all wrong. :rock:
