Electronics PWM fan controller article
Discussion in 'Modding' started by xandman, 3 Aug 2002.
  1. xandman
    xandman What's a Dremel?
    2 Aug 2002
    all i can say is. my rheobus now works! thanks to cpemma!!! i copied your circuit and added a LED. though my voltage rating is just 10v, it'll be fine for me. but, im wondering how i can amplfy voltage? i want it to reach 11.5v or 11.7v :D
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Which circuit?
  3. xandman
    2 Aug 2002
    this one:
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You'll only get about 10.3v max output with a 317, for a bit more use my emitter-follower circuit (to 11.3v) or for even more (11.8+) macromans low-drop-out regulator. For the full monty, the diobus. :dude:
    Link in Useful Links
  5. xandman
    2 Aug 2002
    which useful links man? here or at cpemma.co.uk?
  6. CrazyJester
    CrazyJester What's a Dremel?
    18 Jul 2002
  7. xandman
    2 Aug 2002
    macroman, is using a PWM. MIC IC are not available here. can you post the emitter follower circuit?
  8. CrazyJester
    18 Jul 2002
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Thanks, CrazyJester, 76 posts, like your new avatar, though mad matador came to mind :lol:
  10. CrazyJester
    18 Jul 2002
    It's Jester from the Puppet Master and its sequels, my actual "Crazy Jester" is nowhere to be found... probably on a backup disk in a pile somewhere :) I might find it, or recreate it, or just leave this on here for a while :)
  11. xandman
    2 Aug 2002
    thanks guys!
  12. xandman
    2 Aug 2002
    btw, if i were to put a LED here:
    where should it be? it gona eat up voltage right?
  13. CrazyJester
    18 Jul 2002
    You'd want to put it across the fan. The only thing is that an led's brightness doesn't scale well with voltage... It depends what you want the led to indicate
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Across the fan as CrazyJester says (with a suitable series resistor calculated on a 11.3v max, eg 390R for a 3.7v blue @ 20mA), but to get a decent dim as you turn the wick down try this idea.. ;)
    The extra 20mA led juice is negligible compared to a typical fan.
