Modding PWM Fans on 1 CPU PWM Header
Discussion in 'Modding' started by Wilkirich, 27 Nov 2009.
  1. Wilkirich
    Wilkirich Don't tell them your name Pike!
    27 Nov 2009
    Hi all,
    Built a new rig delighted with it.......but my Mega Shadow has two fans.......bought 2 PWM
    Sharkoon......and an Akasa adaptor ....this works great but ....MB keeps reporting CPU fan error as power is drawn from PSU as opposed to MB header.
    Reading MB info the header will withstand 26w of power draw. My fans only draw 2.6w each.
    I would like to connect the fans together and connect them directly to MB so that the error stops and I also get an RPM reported in Probe sw. Do I simply splice the wires together....omitting the RPM wire to the second fan (only pwm,power,gnd).........
    I am afraid of making a wiring blunder and smutting the board.....will PWM control the speed of 2 fans simultaniously????
    Could somebody provide me with a little wiring diagram..............
    Hope you can help
    Richard
    920
    Mega Shadow + 2 Sharkoon PWM fans
    Asus Rampage 2 Extreme
    6 GB Supertalent 2000mhz DDR3
    850w Seasonic Modular PSU
    Adaptec SCSI 2960 with 140GB 15k drive
    GTX 260 BFG Overclocked
    CPU 1.3v 200mhz BCLK 4ghz at 29deg idle (not fully stress tested yet)
    Stock 26 Deg idle
    Vista Ultimate 32bit (Changing to 7 shortley)
  2. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    As you've said -
    Splice the red to red, black to black but only use 1 yellow sensor wire
    Google ' Daisy chaining fans ' , if you need more info.
  3. Wilkirich
    27 Nov 2009
    Hi thanks for the reply............my fans are four pin........so this is what I intend to do.........
    The wire colours are...
    Black....power/grnd
    Yellow .....power/gnd
    Green = RPM???
    Blue = PWM
    I was intending to wire.............
    Yellow,Black,green,Blue (pwm) to 1st fan as std.......... then connect second fan
    using yellow,black,Blue (pwm)..........leaving green out......I think this is the RPM feedback....
    if you connect this it screws up your fan speed readings.......
    Is this ok
    Richard
