Cooling Pwm fans
Discussion in 'Hardware' started by LooZypher, 23 Sep 2011.
  1. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    Hi all.
    I've bought 4 Scythe Slipstream fans with pwm control dead cheap on ebay.
    I don't realy need pwn control as i have a fan controller, and now I want to know if I can cut the PWM wire and let the fan controller take over?
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    If you're talking about a fan controller with 3-pin connections (which most of them have), there's no need to cut the 4th wire as it will be unconnected and therefore won't do anything. You can leave the 4th wire intact and still control the fan with voltage control.
  3. LooZypher
    4 Jan 2008
    Thanks man ;o)
  4. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yeah.. cut the wire and it'll go 100%
    it's the blue wire usually- well if it's on a 3 pin just leave it.. didn't see that till read lennys =] you can do this on video cards too if want the fan to be out of control
    I have one of those slipstream fans.. they are garbage man! they don't blow any air
  5. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Don't mean to hijack the thread, but what do you need to turn a non pwn fan into one? I.e a Gentle typhoon?
  6. thehippoz
    19 Dec 2008
    a fan controller
  7. GregTheRotter
    9 Aug 2008
    no i mean without one of those xD I'd like a motherboard connector of some sort if possible? Do they make those? Easy to attach etc?
  8. LooZypher
    4 Jan 2008
    Ha! you gotta learn somehow :duh: :hehe:
    Well nevertheless I bet they´re better than my current ones: they blow, and not at all in a good way! :worried:
  9. LooZypher
    4 Jan 2008
    You can't, not without an exteriour fancontroller
  10. thehippoz
    19 Dec 2008
    yeah well it works.. just didn't put out the cfm advertised- was really disappointed cause on paper it looks so good
