Electronics PWM Thermal controller “Bells & Whistles version”
Discussion in 'Modding' started by haloumis, 6 Mar 2004.
  1. haloumis
    haloumis New Member
    21 Feb 2004
    Hello. I just build the “Bells & Whistles version” pwm with thermal control at http://www.cpemma.co.uk/thermal.html . The circuit doesn’t work for me and I can’t fuggier why since I don’t know much about electronics. The circuit design is correct and according to the diagram.
    I didn’t put the IC power connections and smoothing capacitors :duh: . I suppose this is the problem but I would like the pro’s opinion before I burn something as usual. Is the schematic complete?
    I plan to install this inside a Q-TEC 550 psu to control the 2 cooling fans, has any one tried it before? Were do you suggest to mount the thermistor?
    Thanks
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Welcome to Bit, haloumis :thumb:
    It certainly has no chance whatsoever of working without the power connections to the IC. :D
    As it says:
  3. haloumis
    haloumis New Member
    21 Feb 2004
    Thanks :thumb: . I guess I should read before I start soldering :wallbash: . No wonder I never made something work with the first attempt.
