Q 4 A Friend: Geil Memory & P4P800
Discussion in 'Hardware' started by JonDixon, 29 Oct 2003.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Just built a PC for a mate a couple of nights ago and used the P4P800 Deluxe mobo with a P4. 2.8HGZ 800FSB cpu and the Geil PC4200 memory similar to that reviewed here.
    When the PC is booting it looks like the memory is running at 400MHz and definately says single channel.
    Is there some settings in the bios or something I need to change to:
    1, get the PC to recognise this memory as dual channel
    and
    2, can I get the speed upto 500MHz
  2. DamoW
    DamoW What's a Dremel?
    2 Nov 2003
    Its a 'feature' of the P4P800 deluxe - you need to be specific about which DIMM sockets you put the memory into:
    Supported configurations for 2 DIMM's are:
    slot 1 + slot 3
    or
    slot 2 + slot 4
    Any other configs, eg using slot 1 + slot 2, cause single-channel mode to be used.
  3. olv
    olv he's so bright
    23 Sep 2002
    They should be colour co-ordinated aswell i think. And regarding the 500MHz, i dont think you'll see an improvement over running it in sync. High speed RAM like that is usually so the RAM can still be run in sync with the CPU even at high fsb's.
    [Off topic] Where abouts in sheffield are you DamoW?
  4. JonDixon
    12 Mar 2002
    Damo - was that rtfm?
  5. DamoW
    2 Nov 2003
    Yeah, they're blue and black respectively.
    [olv: Deepcar, nth Sheffield]
