Case Mod - In Progress Q-vent 900 - winner MotM feb. - customPC article
Discussion in 'Project Logs' started by FrooP, 16 Nov 2008.
  1. FrooP
    FrooP can I eat this?
    24 Oct 2007
    sorry for the copypasta, but i wanted to show you every step of the designs i made, so on with the copypaste:
    may i present you
    Q-VENT 900
    Supported by:
    yes, its an antec 900 ill mod, so what do i want to do?
    • Rebuild the front so it works as a watercooling reservoir (blue part)
    • fit in a 360 Radiator
    • cover the front in black mesh (i guess hex)
    • make a cover for the motherboard and the PSU (shown below)
    • Remove drivebays (done that already)
    • make a custom hdd bay and attach it to the top
    • remove the top fan and replace it with a DVD drive
    • water cool almost everthing, including:
    CPU, GPU, voltage regs, northbridge and the southbridge.
    some more pics of what i thougt (the cover part where the pump is located is NOT final)
    and some pics of the beta cover
    and that was my first cover layout
    more sketches:
    im going to rebuild the top so the dvd drive fits in nicely
    the watercooling hoses:
    made some paper progress, the cover with sidepanel on
    and the new top
    the top, ill redo the layout though, dont like its look, to messy :/
    Drive open
    Drive closed
    so, hi again with some new updated and more final sketches of the soon to start mod, the new top
    and i also redesigned the front, which still works as a WC reservoir
    the outer shell is made out of black acrylic with little windows in and behind them is the actual reservoir made out of clear acrylic
    the harddrive cage will be custom made and fit under the top of the case
    ill also make some memory coolers for the video cards
    and the best part at the end, the cover ill make out of aluminium
    theres also a 120mm fan added in the bottom
    with its own fanduct :up:
    ill also get some custom made water blocks for the mainboard
    and now, random shots:
    rendered with kerkythea plugin
    im currently in the stae of drawing the cover onto the aluminium, but im working now which..
    sucks :/
    first batch of pics, cleaned the shop today and made a nice foto booth 8)
    so nice lightning and nice background = full win
    plexi glue
    a stringe to apply the glue
    random cables
    NEW FILES <3
    and this time REAL plexiglass
    transparent blue
    extreme shiny black
    and fully transparent
    anyways update time, drawed some of the stuff on the material
    oh what a fun work to draw
    oh heck i hope those wont break while filing :/
    and the top
    and lastly the cover
    its in the shop now :eek:
    jigsawed the cover
    after 3930 hours of filling and 34 kilogram of fine aluminium dust
    everything straight yay
    drilled 2 holes
    and the first one is done, but, failed :/ looks not cool
    next up, guess what, yeah filing x.x
    improved my filing vise, welded a metal bar on it (at least i guess i did), previously the pieces i wanted to file where hold by a piece of junk wood
    so, yeah, thats what i could do
    another epic pile of alu chips
    everything IS straight o/
    thats where i stopped, my thumbs hurt and i need to get some cutting disks because filing these take ages :/
    almost there
    quick sh00p
    guess what, i made a bending brake lol
    i shall call this, ghetto wet-shirt-air-filter-thingy
    but yeah, needed some cutouts for the hinges
    cutted and marked the holes
    yeh, ghetto wet-shirt-air-filter-thingy, didnt worked that well, so i made a even more ghetto mod, old dryer hose house connnectionthingy reused
    works :D
    so, hours later i was done
    and my first test bend (didnt payed attention for the angle)
    after the first test i covered the brake in paint to prevent rusting
    today i made the step which was most afraid of, bending the cover:
    while bending
    damn straight :eek:
    aaaaaaaaaand done, whew
    and painted the inside flat black
    so thats all copypasta i had, next up are the real updates
  2. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    The 'space-ship' design looks really nice imho. Wicked filling skillz, I would have given up at hole number 2 or somethin' xD
  3. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Very cool design Froop, I really like the cover you made. You should make the custom hard drive cage look the same, instead of those round holes. Keep up the great work! :thumb:
  4. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Nice start !
    lot of pictures !!
    I didn't know you could make renders that looks that good in kerkythea :D
  5. skullen
    skullen Minimodder
    31 Oct 2007
    Nice one FrooP very nice :thumb:
  6. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Cool design reminds me of the space suit in dead space.
  7. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Looking great so far, love the sketch-up design. In the sketchup I noticed the cd drive under the mesh in the original exhaust section, you plan on painting it black so that it's more stealthed and hidden? Think it would look better that way, as your putting soo much work to hide / stealth things, then you just see the grey box with the sticker through the top mesh. Good luck, looks awesome already!
  8. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Wow really unique, i love the placement of the optical drive!
  9. ChurchofVirus
    ChurchofVirus What's a Dremel?
    17 Oct 2007
    That is some excellent metal work. Generally I don't dig the sci-fi themes, but yours has some sick style. Keep up the good work! :thumb:
  10. turboshifter
    turboshifter What's a Dremel?
    29 Oct 2008
    epic file job
    must have taken forever
  11. jhanlon303
    7 Sep 2006
    I might file away at stuff for an hour but this is brilliant.
    Nice work.
    john
  12. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    Can not weight to see this thing done, im looking forward to tearing in to my 900 when Im done with my lian li
  13. Cheapskate
    13 May 2007
    Nice. I like what you did with the dvd drive. It seems like they should have made the case like that in the first place. Excellent file work.
  14. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    I'll join in with the accolades! End result looks great, planning looks great, painting looks great.
    I really like your tool setup as well. That filing jig rocks, and the metal bending brake looks good too! (did you score the bend line before to get sharper curves, or just leave au natural? Nice work.
    i'm curious about your idea for the reservoir, will that be 2 thin vertical tubes on either side of the rad? That sounds pretty unique, and interesting. (if so I like it, if not, do tell more please!)
    oh yeah, what was the ghetto wetshirt/dryer hose fan filter thing for? Clean up of metal shavings from filing?
  15. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    nice work, great planning. I also like what you did with the DVD drive. Mine always seemed to kill the front look of the 900.
  16. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Looking good so far...
    Awesome work on the filing. I remember having to do so working for my dad in the body shop... I bet it was a pain in the tail.
  17. psychoti
    psychoti What's a Dremel?
    6 Mar 2008
    keep working mate! :pppp
  18. FrooP
    24 Oct 2007
    guess what, yeh filing LOL
    think of the original front, just filled with water, voila, the reservoir (of course i WONT use the original front)
    i removed the rust from the iron with my angle grinder, dusty you know? ;)
    yep ill paint it flat black
  19. FrooP
    24 Oct 2007
    CORN! YAY erm
    updates n stuff
    i finally found a somewhat fitting design for the pump, so here is a alpha design: (dont mind the water exchange, ill change it to something less cheesy and wrong)
    and just because i can, i designed a dual external hdd/usb hub case (also alpha designs)
    yay!
  20. Trip.X
    Trip.X What's a Dremel?
    16 Nov 2008
    Realy nice design, your are a pro in SketchUp.
    I can't wait to see the final product.
