Case Mod - In Progress Q-vent 900 - winner MotM feb. - customPC article
Discussion in 'Project Logs' started by FrooP, 16 Nov 2008.
  1. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Cuts and design are excellent. Good work!
  2. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Looking real good m8. That cover looks excellent.
  3. headala
    headala What's a Dremel?
    9 Oct 2005
    Wow, still looking great!
  4. FrooP
    FrooP can I eat this?
    24 Oct 2007
    pump cover, cba to explain :p
  5. Guest-23315
    Guest-23315 Guest
    Looks really swish!
  6. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Does indeed. Good stuff :thumb:
  7. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    I liked much better the unpainted aluminum pump cover; (i do love contrasts)
    :waah:
  8. headala
    9 Oct 2005
    Wow, great cover; it reminds me of the old AC Full-Metal-Jackets.
  9. FrooP
    24 Oct 2007
    thanks guys =)
    the dust was a problem.. so i removed it, but guess what.. MORE DUST Òó
    sunshiiiiiiine
    next up, ill make the front =)
  10. The boy 4rm oz
    10 Apr 2008
    Looking really goof FrooP.
  11. FrooP
    24 Oct 2007
    ya,
    made a holder for my mp3 player
    glued on the wall with hot glue, sturdy as w00t
    and it also works still
    then i saw, filed, milled, and sandet the front
    quick setup
    dirt
    glued
    yeh, thats all again..
  12. Jeddy
    Jeddy What's a Dremel?
    12 May 2008
    Wow FrooP, you have brought me out of my current lurk-dom!
    I'm going to be modding a 900 for a contest on another forum (which, unfortunately means I cant post the log here :( ). Your work is certainly an inspiration for my a900 mod.
    I love the radiator placement, and the way all the covers fit together perfectly.
    How is the strength of the case? Since you removed the 5.25" bays, which are a big part of the frame of the case?
  13. The boy 4rm oz
    10 Apr 2008
    Why can't you post it here? We would love to see your work. Make sure to post up completed pics.
  14. FrooP
    24 Oct 2007
    took a day free from work so i was able to mod a bit
    i sanded, filed the front and stacked the parts on top of each other so the little windows line up perfectly
    my method for straight cuts
    and yes, every single cut is STRAIGHT <3
    then i started to tap the outlet for the pump
    some drilling and taping later
    its starting to take shape :)
    cant wait to get in the shop tomorrow
  15. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    It may be similar to (or the same!) contest I'm involved in on another forum. Rules are that it can only be logged in their private section, then after a certain date that log gets opened to the public (on that site) for voting... after that I think it's ok to release the pics.
    End off topic
    FrooP, nice drilling and cutting!
  16. The boy 4rm oz
    10 Apr 2008
    Cuts look dead straight mate, nice work.
  17. Jeddy
    12 May 2008
    I know you! Your logging lexa on that site XD
    Nice work froop, cant wait to see the completed res, should look fantastic.
  18. headala
    9 Oct 2005
    Great work!
  19. FrooP
    24 Oct 2007
    so, progress, im currently looking for someone who can lasercut the front, because i messed it up again :/
    so anyways, i was browsing a random hardware supply marked and guess what i found:
    CHEAP HARDDRIVE WATERCOOLERS YAY
    i need two of em
    the rest of the day i converted my eheim pump to 1/4" threads, which destroyed the pump :( BUT i was able to fix it with some resin, it still leaks, but ill fix that at work tomorrow
    one of the cooler leaks a bit, but nothing mayor i cant fix
    ModMinded and Voluntary_Pariah like this.
  20. MikeMania
    MikeMania What's a Dremel?
    25 Feb 2009
    wow, genius!
