Case Mod - In Progress Q-vent 900 - winner MotM feb. - customPC article
Discussion in 'Project Logs' started by FrooP, 16 Nov 2008.
  1. FrooP
    FrooP can I eat this?
    24 Oct 2007
    so, current status in gluein
    some better shots of the feet
    and bought some white delrin on ebay, yes, for no reason :p
    days ago i recieved my mdpc-x sleeve, heres what it looks like
    lasercut stuff arrived
    then i started making a cover for the front
    the same out of styrene
    then i made a cover for the plexi strip on the rad cover
    glued some aluminium foil in there and added some leds
    neat
    even more when you turn the shutter speed down :p
    since i had to remove the radiator to fit that thing in, well, was to bored, so these are the only shots ive taken
    lights off
    gotta remove some dust
    more tomorrow
  2. Guest-23315
    Guest-23315 Guest
    Wow, those are some intense LED's...
  3. stuartwood89
    20 Aug 2008
    Nice work on the bending.
  4. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    This is one seriously amazing worklog. Wonderful attention to detail.
  5. B4TM4N
    B4TM4N Ninja
    11 Aug 2008
    Looks fantastic!!!!!
  6. The boy 4rm oz
    10 Apr 2008
    Man those laser cut plexi bits look great. I can't wait for this to be all together, it will look insane.
  7. FrooP
    24 Oct 2007
    the bottom part is almost done
    with the case
    after that i disasembled the whole case to fit the led unit in, the result wasn as pleasing as i hoped :(
    even worse in complete darkness
    first coat of primer
    then i made a cover for the harddrive drawer
    then i started gluing the new front
    and another coat of primer...
    yeah
  8. The boy 4rm oz
    10 Apr 2008
    Dude, looks awesome. I really like you you are having the hoses and SATA cables run out of the case than back in, most people would have stealthed em, I like that.
  9. kenco_uk
    28 Nov 2003
    Sha-wing!
  10. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Wow very nice.
  11. verdi
    verdi What's a Dremel?
    12 Feb 2009
    congrats on the win Herr Froop. I live in Germany as well and also do all my work in the cellar. mmmmm fumes and material dust.
    and my neighbours now hate me. Dremel on alu isn't noisy is it?
  12. FrooP
    24 Oct 2007
    hey,
    i still havent recieved my motm stuff *hinthinthint* but ill have an update for you guys
    and ive made a new cover for my modem and my router
    then i started with the top section
    its 15mm square aluminium, which isnt THAT cool to work with
    everything will be held togehter by m4 screws
    and some aluminium angles
    right under the removable top/vent sits the dvd drive
  13. haakon.t
    haakon.t :)
    8 Dec 2007
    Looks awesome! Can't wait to see how the removable top comes out :D
  14. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I'll second that, great stuff! I wish I had a workshop like that as well :dremel:
  15. monkey120101
    monkey120101 My right hand is a Dremel.
    26 Nov 2008
  16. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    SWWWWEEEEETTTT!!!
  17. FrooP
    24 Oct 2007
    so i swapped out the 20y/o main shop light
    with this one
    then i finished the frame, added some angles to the dvd drive and made the sidecovers
    yeah thats all
  18. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Dude, that looks seriously good
  19. Spyrious
    8 Dec 2008
    Very nice.I thought at first that the aluminium frame is a handle.
  20. Huca
    Huca What's a Dremel?
    15 Oct 2006
    this is looking great!
