CPU Q6600 Upgrade to i3 530?
Discussion in 'Hardware' started by Telltale Boy, 4 May 2010.
  1. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    Well i got the biostart tpower I45, and i kept all 4gb of the stock ram, i'm not a massive beleiver in fast ram...
  2. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    As I said before my failed packard bell BIOS prevents any overclocking. :(
    The Biostar seems like a solid choice if it was stocked anymore.
  3. Telltale Boy
    3 May 2010
    Damn, double post sorry
  4. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    Most people never get that far, its a misconception most chips will too.
  5. GingerFox
    15 Nov 2009
    I got mine from someone on these forums, try ebay?
  6. Tesla effect
    Tesla effect AKA ZombieKiller1
    24 Jul 2009
    There's not many P45 mobos around now. Scan are selling an Asus P5Q Pro Turbo for £100. If I remember it got a decent write up in CustomPC. How much RAM do you have in your current rig? You don't really want to have to buy RAM as well as that would cost up to another £100 for 4GB.
  7. Telltale Boy
    3 May 2010
    I had just been thinking that the P5q Turbo looked good when I read your post :hehe:
    I currently only have 3gb ram (can't remember wether that's 1x3gb or 1x2gb + 1x1gb), should that be enough?
  8. Blackmoon181
    Blackmoon181 Geography,Its not just colouring in
    23 Nov 2008
    when i build my PC about 18months ago i bought a Q6600 and Asus P5Q pro. Got it up to 3.4ghz without any voltage tweaks and that being a complete newbie to overclocking. both ebuyer and scan have it for a snippet under a £100. If i remember correctly i got the motherboard on the basis of a good bit-tech review. I think its a pretty general consensus that overclocking your cpu would be the best option solely on the basis of gaming.
  9. Telltale Boy
    3 May 2010
    Ok, my current upgrade list is this:
    1GB XFX HD 5770 £136.05
    Asus P5Q Pro Turbo £99.76
    Xigmatek UTGARD Case £64.50
    Gelid Tranquillo Heatsink Fan £26.05
    Total: £326.36
    Only thing im wondering now is wether it's worth it to upgrade from 3 gb (possibly unbalanced) RAM to 4gb RAM for about an extra £90
  10. Tesla effect
    24 Jul 2009
    I just looked it up. It was back in Aug 09 & it was the Asus P5Q Turbo which is a different board. If tech naming convention had any logic then it would stand that the Asus P5Q Pro Turbo should offer more, the Pro has extra PCIe slot. Blackmoon, the 3.4Ghz is most likley the CPU limit as well as noted previously in this thread. That's my stable limit on a Biostar TP45 HP with a Q6600.
    Oh & 3GB of RAM is no good you need 2x2GB modules to run in dual channel. 2GB isn't enough.
  11. Tesla effect
    24 Jul 2009
    Shop around for RAM. At Scan your paying more for Corsair, although the RMA support is excellent. You will be fine with 800MHz RAM as well.
  12. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    I run a Q6600 on an Abit IP35 Pro with 4GB (2x2GB of Corsair XMS2 800MHZ ) I have a 3.4GHZ OC on a passive Scythe Ninja cooler, inside an Antec 1200.
    Still runs what I play perfectly, and thats with a 24" main and a 20" secondary.
  13. Telltale Boy
    3 May 2010
    Cheers guys, i've managed to sort out an upgrade that includes 4gb Crucial Ballistix memory fory roughly £380. I'll post it tomorrow when I have more time.
  14. samkiller42
    25 Apr 2006
    You getting it from Scan, or going down to Novatech? I used both Novatech and Scan, but for sheer convenience, Novatech wins for me, thus i kinda get everything from them now.
    Sam
  15. rollo
    rollo Modder
    16 May 2008
    If you can't overclock and have a decent psu
    stick a 5850 in it and you will notice a much bigger boost than anything suggested here
  16. zpikez
    zpikez mod-pirate
    25 Jul 2009
    i actually upgraded from a q6600 to an i3 myself, id never look back, if its in your budget though go for an i5
  17. Telltale Boy
    3 May 2010
    Well here's my current list of upgrades:
    Components from Ebuyer:
    Components from Scan:
    Thats comes to £429.69 (however now I think about it, I could reuse my 750GB hard drive & my dvd drive, knocking off about £50)
    This the one i'll be upgrading from (just reposting it)
  18. 52735
    52735 What's a Dremel?
    1 May 2010
    I have this. No problem.
  19. Arj12
    Arj12 What's a Dremel?
    6 May 2010
    How much of a speed increase do you see on it?
  20. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Seems to be a good upgrade from your current build. I think you will enjoy it very much. Try to find out the what your hard drive is with the help of stickers on it, if any.
