CPU Q6600 v Q6700 v Q8200
Discussion in 'Hardware' started by [PUNK] crompers, 2 Dec 2008.
  1. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    Im looking at getting a quad core for christmas, which of the above you buy? they can all be had for around the same price (about £20.00 in it)
    Im comfortable with OCing but i wont want to be taking it further than 3ghz, i understand the 6700 has a 10x multi which could be helpful.
    All opinions welcome :)
  2. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Do they all have the same cache size? if so buy the cheapest, 3ghz isn't pushing any of them.
  3. [PUNK] crompers
    20 May 2008
    just noticed the Q8200 has 4MB compared to 8MB for the other two. Apparently tho there have been some core revisions for this model, anyone have experience?
  4. ATLPIMP
    ATLPIMP oooh, shiney
    2 Dec 2008
    Q6600 has 8Mb (2Mb X 4) cache, and new G0 stepping almost guarantees 3GHz without added voltage (9X333).
    Mine is happy at 7 X 430 at 1.27V after 100 instances of IBT.
  5. [PUNK] crompers
    20 May 2008
    yep i know the Q6600 G0 is a great processor. i suppose my question is would there be any reason to buy either of the over two over a Q6600?
  6. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
  7. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    The 8200 is only a dual core compared to the other two which are quads, so i'd discount that straight away if it's a quad you're after!
  8. [PUNK] crompers
    20 May 2008
    straight answer to a straight question, thanks :thumb:
    If you look thats a Q8200 and not an E8200, its a new quad core chip
  9. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    Yep, there is a quad core chip with the same serial number - it runs at 2.33GHz. The Q6600 has a clock speed of 2.4GHz, so its faster stock. AFAIK, the Q6600 overclocks *a lot* better than the Q8200. The Q6600 is the one to go for. Incidentally, mine arrived today :D. Looking forward to overclocking it.
  10. hodgy100
    hodgy100 What's a Dremel?
    2 Jun 2008
    I got a q6600 the other day, havent used it yet though, i have to wait for christmas before i get any other parts i need :(
    I bought it based on the fact that peopel have been able to overclock it really easily, and as this will be my first time overclocking properly, i have made it easy for myself :)
  11. [PUNK] crompers
    20 May 2008
    thats sorted then im bagging myself a Q6600
    Im hoping my Freezer 7 Pro will be able to cope with 3ghz?
  12. heir flick
    heir flick Minimodder
    2 Feb 2007
    my q6600 is running at 3ghz with a arctic freezer pro easy, read talk of the q6600 being discontinued so grab one while you can
  13. [PUNK] crompers
    20 May 2008
    ok thanks, ebuyer have 400 in stock at the mo so hopefully i'll be ok
  14. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    The q6600 gets 3ghz easy, however make sure you choose a suitable motherboard otherwise it may be a bit of a struggle.
  15. [PUNK] crompers
    20 May 2008
    ive got a GA-P31-DS3L, been OCing my e4500 all year on it so its all good
  16. [PUNK] crompers
    20 May 2008
    further musings
    just spotted that i could have a q9300 for £40 more, worth it?
    :edit: just though soddit and ordered the Q6600, saved myself £40 and got a decent multiplier
