Storage QNAP TS-412
Discussion in 'Hardware' started by ikix, 17 Mar 2012.
  1. ikix
    ikix What's a Dremel?
    18 Nov 2009
    Hi,
    I'm looking at getting the QNAP TS-412 along with some Seagate 2TB ST2000DM001 Barracuda hard drives. The QNAP is rated for SATA II but these drives are SATA III, they are in the compatibility list so things should be fine but I am still a little concerned with regards the SATA II/III compatibility, should I be? Having looked at SATA II drives they are for some reason a lot more expensive so it makes sense to grab the SATA III drives.
    Thanks,
    iKiX
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    No need to worry, SATA III is completely compatible with SATA II, only the speeds will cap at 3 Gb/s (if it even reaches that speed)
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    The network connection will be the limiting factor in a NAS!
  4. mikeyman198
    12 May 2011
    Yes, but he was worried about the SATA ports, not his networking :)
