Guide QT110 Touch-Sensitive Button Guide
Discussion in 'Modding' started by gongzero, 16 Oct 2005.
  1. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    where can i get the parts in the UK without having to have an order of over £20?
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
    farnells is I think the only place i the uk
  3. talladega
    18 Aug 2007
    argh!
    Ok so, I swapped the two I mixed up. Still wasnt working then, because it's an SPDT relay I checked which two pins are connected when the circuit is at idle. I had the dvd drive hooked up to the wrong ones. So I switched them and using meter to test continuity on the + and - of the drive button when I touch the electrode of qt113 it beeps meaning the + and - are being connected.
    It seems the drive will open if I connect the volt meter to the + and - the drive then unconnect them. Not sure why.
    Makes no sense at all!
    Heres how I have it
    The relay is working perfectly as it should.
    EDIT:
    Just did some testing. Took aanother relay and soldered wires to the pins that are normally close and touched those to the + and - of the drive. The drive opened!
    So I know for sure this relay is working perfect and the lines are connecting 100%
    So now then WTF is messing it up when I have everythign else attached?
  4. dan-ere-07
    29 Mar 2007
    thanks for the help :thumb:
    i guess ill have to just make a list =]
    nice circuit for opening a cd drve, but i didnt think the button on a cd drive had a + and a -
  5. talladega
    18 Aug 2007
    well one is gnd and other is 3.3v
    so thats + and -
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    You've wired something wrong for sure. If the positive side of the dvd switch has 3.3v, then the first pnp diagram i drew should have worked, and a relay should work aswell. [​IMG]
    Just make sure every wire is not only connecting the correct points in the circuit, but make sure that there is actually a connection, as in ~0 ohms.
    Unless, perhaps it is as simple as a broken wire?!?
  7. talladega
    18 Aug 2007
    no broken wires, everything is done up 100% right. ive used a spare relay and just connected the two normally close pins to the drive wires and it works. i dont know anymore.
    very frustrating.
    whatever.....
  8. spanky77
    spanky77 What's a Dremel?
    17 Nov 2008
    Hey guys, I'm working on a computer project similar to this ONE, and wanted to know: Since I'm no good at electronics, could I use THIS to do the same thing as the item that originally started this thread? This of course is as long as my power supply isn't over 300W
    Thanks,
    Spanky
  9. Nexxo
    23 Oct 2001
    Nope, don't think so.
  10. mvagusta
    24 Dec 2006
    @Talladega:
    1) So you short the two pins of the dvd eject button and it ejects, correct?
    2) You correctly connected the relay to the touch switch & dvd buttons, when triggering the touch switch, the relay was activated, which you have confirmed with a multimeter, but the dvd tray did not open?
    If you answer yed to both of these questions, then one or more of the following is occuring:
    a) you messed up the wiring
    b) you have a broken wire
    c) you have a faulty connection
    d) you think the relay works but it doesn't
    e) you aren't connecting to the correct pins of the dvd drive?
    f) you think the dvd is working reliably but it intermittantly opens when using the eject button!
    g) your pc is possesed, burn it at the stake, now!
  11. talladega
    18 Aug 2007
    Not very helpful am I? :lol:
  12. cs2000
    cs2000 What's a Dremel?
    24 Apr 2009
    i know it might be cheaky but could anyome make me up two of these circuits. I need one for a power button and the other for DVD drive eject. A small piece of metal will act as the switch button. I know it might be alot to ask but would really appreciate it and such a thing is vital to my project. Of course i would pay for materials and your time to make them if anyone could do it for me. Im in england BTW.
  13. Atheistmunk
    Atheistmunk planing future mod
    27 Feb 2009
    ok so i have no clue how to do anything with electronics other than pluging something into something else:duh:
    is there a place where i can buy 2 of these (one for dvd eject and one for pc power)
    thanks
  14. cs2000
    24 Apr 2009
    i basically need to do the same :p or something that will do exactly the same task as this
  15. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    I do believe you can order development kits from Atmel that use these chips (although I believe the Q110 has been discontined). Atmel bought out Quantem Research on the touch sensor stuff, if I remember correctly. The kits come as a already made kit, so you just hook up your external devices. Prices were fairly resonable, I believe too....maybe $15-$20 or so.
    Link to kit: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4473
    mvagusta and Atheistmunk like this.
  16. Atheistmunk
    27 Feb 2009
    that is excactly what i needed thank you!:clap:
  17. One~Zero
    9 Sep 2004
    Just make sure you check the datasheets for the output of the kit. Some may pull the output to ground or up to VDD, or be momentary or latching. I remember the older 110 kits had selectable jumpers for the momentary or latching, and different ic's provided either the pull up or pull down output.
  18. cs2000
    24 Apr 2009
    need to find one of these who will ship to the UK... no luck so far :(
  19. edm3d
    edm3d What's a Dremel?
    29 May 2009
    Hi im new here and i want to congrats you all for the excelent forum, i have been reading it for a while now.
    i was doing some searching about qprox IC when i found this thread. after read the whole thread i learned alot bout how to do my DIY touch sensitive button. I liked some of the ideas i saw, particullary the idea of mvagusta of double clicking button.
    The problem is that the images of the circuit that he posted are down, so im asking if someone can post the circuit again or another circuit that do the same thing.
    Thanks, and sorry for my english:thumb:
  20. cs2000
    24 Apr 2009
    I see farnells sell plenty of evaluation boards by quantum research but can anybody tell me a place where I can but two of these boards to use as a pc power switch that will be activated by a metal plate.
    I don't mind if somebody builds me them and il pay for the service.
