Electronics QTouch chips
Discussion in 'Modding' started by ellism, 10 Apr 2004.
  1. ellism
    ellism What's a Dremel?
    10 Sep 2003
    Have seen these chips on here and am ondering where they can be purchased in the UK? spesificaly the qt110 8-dip version. Here comes totaly stealthed CD heaven.
    -->p.s. not sure if i have psoed this in the rigth place
  2. davew
    davew What's a Dremel?
    13 Mar 2004
  3. ellism
    10 Sep 2003
    sadly no good, don't except paypall/solo :(
  4. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Digikey accepts Solo and stocks the QProx chips. However, Digikey does have a minimum order requirement, so make up excuses to get other stuff if you were only after the QT110.
  5. coorz
    coorz Miffed
    25 Apr 2003
    Farnell should be your friend. Sadly they only stock QT110-H in DIP8.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I have, no problem. Takes about 10 days, VAT & duty-free if order under £18 (about $30) :thumb:
  7. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    You could always get a PLCC version and get a PLCC socket if it comes down to it. Though DIP is easier to work with than small PLCC chips.
  8. TheAnimus
    TheAnimus Banned
    25 Dec 2003
  9. ellism
    10 Sep 2003
    would be about as much hastle getting the debit card as finding a shop for these things
  10. ellism
    10 Sep 2003
    orderd them now from fernell, now that my mums home and i can use her card. :thumb:
