Windows Quad boot system not starting XP
Discussion in 'Tech Support' started by Shielder, 6 Jan 2010.
  1. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Yup, quad boot. XP, Vista, 7 and Fedora 12.
    I installed Fedora 12 onto my 320GB drive and got the system to boot from that drive (SATA-2) instead of the primary 200GB drive (SATA-0) which contains XP and 7.
    Vista resides on SATA-1 and is unaffected.
    I can boot into GRUB which gives me the option of booting Fedora or Windows.
    I choose Windows (Linux works) and am presented with the Windows boot loader screen with the three options, XP, Vista and 7.
    If I choose Vista or 7, all is okay, but if I choose XP, the system reboots in a second. No splash screen, no error, just a reboot.
    I've tried using the XP CD, but it requires SATA drivers (Q1: How do I burn a disk with the SATA drivers already on?) which the system says are corrupted, but which Vista and 7 can read ok.
    Now, all of my games are on the XP partition (the 200 GB disk is shared with 7), which was working after I installed Fedora, but which is not working now (7 is okay). My question really is this, what can I do to sort this out? Is there a way to fix the MBR from Vista or 7? I can't remember where GRUB points me to with the Windows boot loader, I'll have to check, it may be the Vista or 7 partition.
    Will I have to reinstall XP or just live with the system as it is? I may be able to install another hard drive and have XP on that...
    Any ideas?
    TIA
    Andy
  2. Jenny_Y8S
    Jenny_Y8S Guest
    Booting 3 different Windows? It's 2010, just migrate your files to 7 and be done with it!
  3. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    You can use nLite to create a new XP CD with the correct SATA drivers preloaded.
  4. adam_bagpuss
    24 Apr 2009
    seems to me like an old XP install i.e one that pre-dates service pack 2.
    had this issue a while back.
    original XP discs dont like SATA controllers and basically crash everytime you try to boot.
    work around is to find a XP disc with service pack 2 or 3 and install from that.
  5. nightblade628
    nightblade628 Minimodder
    10 Dec 2009
    Not trying to be judgemental or anything, but since Windows 7 is basically just Vista 2.0, why have both?
  6. Shielder
    26 Jul 2007
    I know. Vista SP2 (aka Windows 7) was on offer before it was released so I preordered it. I wasn't going to install it but gave in to the temptation...
    Anyway, I've got XP SP2 but it still needs the SATA drivers. nlite looks good, can I run it from Vista or 7?
    Oh and Jenny, there are programs I use that don't run under 7 Home Premium.
    Andy
