Build Advice Quad Core build for £300 need help
Discussion in 'Hardware' started by flame696, 17 Aug 2009.
  1. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Hi guys
    Building a system for my brother and he doesnt want to spend over £300 but he wants a quad core system :wallbash: ive tried to find the stuff on scan and heres what i have come up with:
    https://secure.scan.co.uk/aspnet/Shop/Basket.aspx
    He want to stick with intel so no AMD if you can find things cheaper it will be a big help
  2. Guest-16
    Guest-16 Guest
    Basket link doesnt work.
    "System" including case, hard drive, cooler and optical? Or just mobo, memory and cpu?
    Former you'd be very very hard pushed, but latter is easy.
  3. flame696
    15 May 2009
    He wants a whole system he doesnt game its just for regular work but he definitly wants a quad core heres what i have come up with:
    Coolermaster RC-330 Elite Blk/Silv Midi Tower Case w/o PSU - £28.97
    2GB Corsair XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-18 22.59
    Intel Core 2 Quad Q8200, S775, Yorkfield Core, 2.33 GHz, 1333MHz, 4MB Cache, 7x Ratio, 95W, Retail - £106.94
    500W CIT Black 12cm V2.2 Dual Rail Psu - £21.84
    640GB Western Digital WD6400AACS Caviar Green, SATA 3Gb/s, IntelliPower, 16MB Cache, NCQ - £44.74
    Asus P5QL/EPU, Intel P43, Sok 775, PCI-E 2.0 (x16), DDR2 1066(OC)/800, SATA 3Gb/s, ATX £57.49
    LG GH22NS50 22x DVD±R, 16xDVD±DL, DVD+RW x8/-RWx6 ,12xRAM SATA, Black, OEM £16.66
    Net Total = £260.19
    Carriage = £9.43
    VAT = £40.44
    TOTAL - £310.06
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    ebay might be your friend here.
    Q6600 would be anywhere between £60-100 depending on age, a P35 motherboard £50 easy and memory definalty under £50, leaving £100 for the rest of the crap needed.
  5. Pieface
    Pieface Modder
    8 Mar 2009
    Operating System? Graphics Card?
    Or is the Graphics card in mobo?
  6. flame696
    15 May 2009
    Oh crap i forgot about the GPU!!!!:wallbash::wallbash::wallbash::wallbash::wallbash:
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
    What kind of work is 'regular work'? If that's just MS Office apps and no encoding/rendering/editing then he won't even need a quad.
    As pointed out, you're going to struggle without an OS. Perhaps just advise him to get something like this if that's all he's going to need.
    There's no point going overboard with a custom build because either way you're going to be getting cheap components.
  8. flame696
    15 May 2009
    yeh i was looking at that too but hes so set on a quad core he doesnt know much about pc's he thinks more numbers equal a better computer and even if he doesnt use it he still wants it. Regular work is MS office, web browsing and the odd video editing, photoshop
  9. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Please god don't sped £21 on a PSU.
    If that blows then its possible for it to wipe out everything.
    Why don't you tell him that for what he wants, a dual will be faster, as it will be higher clocked.
    And that for his budget, its near....no, it is impossible to build a Quad core system.
  10. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    There are plenty of LGA775 motherboards on Ebuyer with onboard VGA - you could go for one of those if games aren't required.
    And the Windows 7 RC is still available - or Linux Mint which is the only distro I've ever managed to get working but is actually very good! If you went with Windows 7 he could buy a full version in March which would give him some time to save up!
  11. docodine
    docodine killed a guy once
    10 Feb 2007
    I don't think he'll be able to get an Intel Quad build for £300 (assuming ~$500), I'll give it a try though..
    Q8200
    Gigabyte EP43-UD3L
    2x2GB OCZ Blade DDR2-800
    Corsair 400CX
    Cooler Master Elite 330
    WD Caviar Blue 320GB
    Zotac 9600GT
    -rebates +shipping = $500
    You'll need to buy an OS or get Win7, and I hope he has a monitor/keyboard/mouse.
  12. flame696
    15 May 2009
    thanks for all your efforts guys for helping me ill either have to tell him to up his budget or get a core 2 duo or a dual core
  13. smc8788
    smc8788 Multimodder
    23 Apr 2009
    That's not too bad, but that exact spec will set you back more than £350 excluding shipping over here, such is the way the exchange rates work :sigh:
    The problem is still the OS, however - it's all very nice have that hardware but you can't even think about using it without one. Another option might be to just use the Windows 7 RC for a bit while saving up for an OS, but at some point you're going to have to buy one.
  14. flame696
    15 May 2009
    What about this guys I got this from novatech its just over budget
    Intel Core 2 Quad Q8200 4 x 2.33Ghz 4Mb Cache 1333 FSB Quad Core Processor - Retail
    £96.84
    Corsair XMS2 2GB (2x1GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit
    £24.99
    OCZ StealthXStream 400w Silent SLI Ready ATX2 Power Supply
    £29.99
    Asus P5QPL-AM Intel G41 (Socket 775) PCI-Express DDR2 Motherboard
    £41.99
    Seagate Barracuda 7200.11 320GB SATA II 7200rpm 16Mb Cache 11ms 300Mb/s
    £29.66
    LG 22x DVD+/-RW Dual Layer DVD-RAM SATA Black - OEM
    £15.76
    Novatech Pure ATX Tower Case - Black - NO PSU
    £17.38
    Novatech ATI Radeon HD4350 512MB GDDR2 TV-Out/Dual DVI PCI-Express
    £24.99
    Delivery Options:
    Total Basket Ex VAT: £281.60 ex vat
    Delivery Charge: £7.39 ex vat
    Basket + Delivery Ex VAT: £288.99 ex vat
    VAT @ 15.0%: £43.35
    Total Basket Value: £332.34 inc vat
  15. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Well straight off you can drop the 4350 to bring it nearly down to budget (albeit still without an OS ;)), as that motherboard has an IGP (G41 chipset).
  16. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    That looks about right.
    yes the motherboard has onboard gfx.
    I've used this board on a couple occasions for cheap builds for friends.
    So far no problems it does the job well!
  17. flame696
    15 May 2009
    The only reason i have the GPu is coz he has an lcd screen with a DVI cable already so i can hopefully persuade him to up his budget to £350 and then i can buy him a couple of 120mm fans for the case and leave me money for drinks;):D
  18. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    BAH! For goodness sake, calm down - not all cheapo PSUs will blow up and take your computer with it - if your buidling a £300 quad core pc your gonna have to make sacrifices, I was running an EZCool 550W for half a year, it was fairly quiet and never gave me ANY trouble what so ever...
  19. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    That looks like a good setup, but you don't need the HD4350. Save the £24.99 and use the onboard graphics instead. :)
  20. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    then you were lucky
